Remove the five #1 Phillips screws (black, 3/16") attaching the cover to the DVD player.
One 3/16" screw on the right side of the DVD player.
One 3/16" screw on the left side of the DVD player (directly opposite of other screw).
Three 3/16" screws on the back of the DVD player.
Use the tweezers to remove the four sets of wires connected to the processing board. Start with the cord located in front of the row of three cords.
The wires may be difficult to remove. Wiggling them while lifting them up may help remove them.
Handle the processing board with care. It is fragile.
Unscrew the two #1 Phillips screws (silver, 3/16") located on the two edge corners of the processing board.
Orient the DVD player so that you are facing the video and audio jacks.
Unscrew the two #1 Phillips screws (silver, 3/16") located on the outside of the DVD player
The processing board is now free to be removed and replaced.
Orient the DVD player so the front of the DVD player is opposite of you.
Remove the two #1 Phillips screws (silver, 3/16") that attach the DVD drive to the bottom of the DVD player.
Orient the DVD player so the button circuit board is facing you.
Remove the four #1 Phillips screws (silver, 3/16") from the button circuit board.
Three 3/16" screws from the longer button circuit board.
One 3/16" screw from the smaller button circuit board.
Push back the black, plastic clip near the left center of the shorter button circuit board.
Pull the shorter button circuit board out of its position.
このガイドを埋め込む
サイズを選択し、以下のコードをコピーして、このガイドを小さなウィジェットとしてサイト/フォーラムに埋め込みます。
プレビュー
