はじめに
If the monitor or screen is broken, the monitor needs to be detached from the Sony DVP-FX730. To detach the monitor successfully, a screwdriver should be used to remove screws, use your hands to pull remove a small back cover, and use tweezers to remove wires attached to bases.
必要な工具と部品
もう少しです!
終わりに
