はじめに
The motherboard paramount for the proper function of the camera, basically acting like a "brain." This guide will serve as check for electronic connections, and a full removal procedure of this critical component.
必要な工具と部品
Remove all the 4.3mm screws on the bottom using a J000 Phillips screwdriver. There should be seven screws (4 silver, 2 black).
この手順で使用する道具:Tweezers$4.99
Remove all ribbon connectors from the motherboard using tweezers. Simply grab each ribbon cable and pull straight out of the connector.
There is a hidden wire on the bottom of the board that should also be removed.
In order to reassemble your device, follow these instructions in reverse order.
2 の人々がこのガイドを完成させました。
