メインコンテンツにスキップ
Sony DCR-DVD 108 Front and Back Lens Replacement
必要な工具と部品
  1. Sony DCR-DVD 108 Front and Back Lens Replacement, Sony DCR-DVD 108 Case Disassembly: 手順 1、 1の画像 1
    • Remove all the 4.3mm screws on the bottom using a J000 Phillips screwdriver. There should be seven screws (4 silver, 2 black).
  2. Sony DCR-DVD 108 Front and Back Lens Replacement: 手順 2、 1の画像 1
    • Remove the 5mm #0 Phillips screws on the underside of the LCD tuck-a-way.
  3. Sony DCR-DVD 108 Front and Back Lens Replacement: 手順 3、 1の画像 1
    • Remove the 2mm #0 Phillips screw behind the battery.
  4. Sony DCR-DVD 108 Front and Back Lens Replacement: 手順 4、 1の画像 1
    • Open the dvd cover and remove the 3 4.3mm phillips screws. Including ones in the corners that may be hidden.
  5. Sony DCR-DVD 108 Front and Back Lens Replacement: 手順 5、 2の画像 1 Sony DCR-DVD 108 Front and Back Lens Replacement: 手順 5、 2の画像 2
    • Once all the screws are removed you can safely pry open the camera case using a spudger.
  6. Sony DCR-DVD 108 Front and Back Lens Replacement, Front and Back Lens: 手順 6、 1の画像 1
    • Take the half of camera containing both lens components and turn front portion towards you.
    • Remove the four 4.3mm Phillips #0 screws pictured.
  7. Sony DCR-DVD 108 Front and Back Lens Replacement: 手順 7、 1の画像 1
    • Remove front lens and inspect for "dirt," smudges. or scratches. Use discretion, if lens appears too damaged, replace part.
  8. Sony DCR-DVD 108 Front and Back Lens Replacement: 手順 8、 1の画像 1
    • Gently pull lens housing to expose housing channel.
  9. Sony DCR-DVD 108 Front and Back Lens Replacement: 手順 9、 1の画像 1
    • With the pointed end of a plastic spudger, press latch located on the side of rear lens housing.
  10. Sony DCR-DVD 108 Front and Back Lens Replacement: 手順 10、 2の画像 1 Sony DCR-DVD 108 Front and Back Lens Replacement: 手順 10、 2の画像 2
    • Once loosened gently pull and remove lens housing. The lens should now be free to inspect and replace.
終わりに
In order to reassemble your device, follow these instructions in reverse order.
作成者
3人の作成者と共同で作成されました。
Elijah DeWolf
メンバー登録日: 02/09/16
589 ポイント
5のガイドは作成済み
チーム
USF Tampa, Team 7-6, Cheng Spring 2016 USF Tampa, Team 7-6, Cheng Spring 2016人のメンバー
USFT-CHENG-S16S7G6
3 メンバー
10のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 12
過去 30 日: 26
今までの合計 474
