メインコンテンツにスキップ
Sony Cyber-shot DSC-WX80 Lens Replacement
必要な工具と部品
  1. Sony Cyber-shot DSC-WX80 Lens Replacement, LCD Screen: 手順 1、 3の画像 1 Sony Cyber-shot DSC-WX80 Lens Replacement, LCD Screen: 手順 1、 3の画像 2 Sony Cyber-shot DSC-WX80 Lens Replacement, LCD Screen: 手順 1、 3の画像 3
    • Begin by removing all six #00 40mm by 10mm black screws holding the outer frame together with the Phillips #00 Precision Screwdriver.
    • Remember to keep track of all screws as they are small and very easy to lose
  2. Sony Cyber-shot DSC-WX80 Lens Replacement: 手順 2、 3の画像 1 Sony Cyber-shot DSC-WX80 Lens Replacement: 手順 2、 3の画像 2 Sony Cyber-shot DSC-WX80 Lens Replacement: 手順 2、 3の画像 3
    • Take note of the small free moving flap near the battery port seen in the first of the three photos. Be sure to store the free moving flap in a safe place.
    • Pry the front cover off gently. Use a plastic opening tool if available.
    • Now pry the back cover off gently, using a plastic opening tool if available.
  3. Sony Cyber-shot DSC-WX80 Lens Replacement: 手順 3、 3の画像 1 Sony Cyber-shot DSC-WX80 Lens Replacement: 手順 3、 3の画像 2 Sony Cyber-shot DSC-WX80 Lens Replacement: 手順 3、 3の画像 3
    • Remove the #00 screw from the right hand side (from the LCD screen side) which is adjacent to the master control dial. Reference the first image.
    • Use a spudger or plastic opening tools to pry up the LCD screen and free the two metal tangs on the left side. Reference the second image.
    • Lift up two more metal tabs held down by a thin red plastic strap on the right (master control dial) side. Reference the third image.
    • The thin red plastic strap is very fragile.
  4. Sony Cyber-shot DSC-WX80 Lens Replacement: 手順 4、 2の画像 1 Sony Cyber-shot DSC-WX80 Lens Replacement: 手順 4、 2の画像 2
    • Using a pair of tweezers, remove the blue ribbon from its connection located toward to the top right of the device. Reference the first image.
    • Using a pair of tweezers, remove the gold ribbon from its connection located to the right of the removed blue ribbon. Reference the second image.
    • Your LCD screen is now removed and you can replace it!
  5. Sony Cyber-shot DSC-WX80 Lens Replacement, Lens: 手順 5、 2の画像 1 Sony Cyber-shot DSC-WX80 Lens Replacement, Lens: 手順 5、 2の画像 2
    • After the LCD screen has been removed there is a black metal plate that can be pulled off revealing the motherboard and the lens.
  6. Sony Cyber-shot DSC-WX80 Lens Replacement: 手順 6、 2の画像 1 Sony Cyber-shot DSC-WX80 Lens Replacement: 手順 6、 2の画像 2
    • To separate the motherboard from the lens there are two ribbon cables that need to be pulled out of their ports using tweezers.
    • Now that the Lens has been removed from the motherboard you can replace it!
終わりに
2 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Scott Grambo
メンバー登録日: 04/08/15
264 ポイント
2のガイドは作成済み
チーム
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 5
過去 7 日: 10
過去 30 日: 22
今までの合計 1,221
