はじめに
Make sure you have the necessary tools in order to complete the LCD screen replacement for the Sony Cyber Shot WX80 and be sure to have a steady hand when dealing with the smaller and more fragile parts.
必要な工具と部品
Begin by removing all six #00 40mm by 10mm black screws holding the outer frame together with the Phillips #00 Precision Screwdriver.
Remove the #00 screw from the right hand side (from the LCD screen side) which is adjacent to the master control dial. Reference the first image.
Use a spudger or plastic opening tools to pry up the LCD screen and free the two metal tangs on the left side. Reference the second image.
Lift up two more metal tabs held down by a thin red plastic strap on the right (master control dial) side. Reference the third image.
Using a pair of tweezers, remove the blue ribbon from its connection located toward to the top right of the device. Reference the first image.
Using a pair of tweezers, remove the gold ribbon from its connection located to the right of the removed blue ribbon. Reference the second image.
Your LCD screen is now removed and you can replace it!
New display purchase old display was damaged
And body was cracked my sister sons throw my camera some parts damaged I need help
4 の人々がこのガイドを完成させました。
2 件のコメント
The replacement includes just the compatible LDC screen and the connector; the wheel is a separate piece.
The LCD comes naked, meaning that the fancy screen protector with black frame is not provided. It is kind of a sticker which shall be detached from the original LCD and re-attached to the new one. It would have been a good idea to include it within the fix tip.
