メインコンテンツにスキップ
修理を始めるには
修理する権利
パーツ&ツール
はじめに
Make sure you have the necessary tools in order to complete the battery replacement for the Sony Cyber Shot WX80 and be sure to have a steady hand when dealing with the smaller and more fragile parts.
  1. Begin by removing all six #00 screws holding the outer chassis together with the Phillips #00 Precision Screwdriver. Remember to keep track of all screws as they are small and very easy to lose Remember to keep track of all screws as they are small and very easy to lose
    • Begin by removing all six #00 screws holding the outer chassis together with the Phillips #00 Precision Screwdriver.
    • Remember to keep track of all screws as they are small and very easy to lose
  2. Take note of the small free moving flap near the battery port seen in the first of the three photos. Be sure to store the free moving flap in a safe place. Pry the front cover off gently. Use a plastic opening tool if available. Now pry the back cover off gently, using a plastic opening tool if available.
    • Take note of the small free moving flap near the battery port seen in the first of the three photos. Be sure to store the free moving flap in a safe place.
    • Pry the front cover off gently. Use a plastic opening tool if available.
    • Now pry the back cover off gently, using a plastic opening tool if available.
  3. Access where the replacement battery will go indicated by the red square in the photo to your left
    • Access where the replacement battery will go indicated by the red square in the photo to your left
    • Now insert your new replacement battery
終わりに
Matthew Schmid
メンバー登録日: 2015年04月08日
404 ポイント
2のガイドは作成済み
チーム
2 件のコメント
Why did you not just open the bottom battery door instead of pulling the camera apart?
Kat - 返信
I am also suprised to know that I should dis-assemble to replace battery. It maybe a joke.
Chung-Suh Ku - 返信
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 9
今までの合計 700
