はじめに
This guide will teach you how to replace or clean a lens assembly in a Sony Cyber Shot DSC-WX350
必要な工具と部品
Use the J00 screwdriver to take out the four 3mm black screws on the bottom and both sides of the camera.
Take the LCD off by undoing the zif and sliding it out.
Don’t REMOVE the zif connector like on the picture!
To open the zif connector:
- this is the black (or the brun part on the other connector) part that pivots, the white part don’t move
- I prefer to use my thumb(s) and my fingernail(s) to control the force
- put your thumb on the side of the camera, just in front of the white part, to avoid the camera to slide toward yourself
- slide you fingernail below the black part
- if you have small finger, you can use both hand to reduce the effort on the zif
- lift up the black part, that will pivot and terminate at 90° angle with the white part
3 の人々がこのガイドを完成させました。
2 件のコメント
Hi there, does anyone know who I could go to to fix the lens (replace them) on my Sony wx-350 camera Thank you!
