メインコンテンツにスキップ
Sony Cyber-shot DSC-WX350 Flash Assembly Replacement
必要な工具と部品
  1. Sony Cyber-shot DSC-WX350 Flash Assembly Replacement, Flash Assembly: 手順 1、 3の画像 1 Sony Cyber-shot DSC-WX350 Flash Assembly Replacement, Flash Assembly: 手順 1、 3の画像 2 Sony Cyber-shot DSC-WX350 Flash Assembly Replacement, Flash Assembly: 手順 1、 3の画像 3
    • Remove 6 black Phillips 4 mm screws using the J00 head screwdriver tip from the sides and bottom of top cover.
  2. Sony Cyber-shot DSC-WX350 Flash Assembly Replacement: 手順 2、 1の画像 1
    • Remove the black Phillips 4 mm screw using the J00 head screwdriver tip from inside the battery inclosure.
  3. Sony Cyber-shot DSC-WX350 Flash Assembly Replacement: 手順 3、 2の画像 1 Sony Cyber-shot DSC-WX350 Flash Assembly Replacement: 手順 3、 2の画像 2
    • Use the plastic opening tool to take back cover off. Then take out the LCD screen with your hand.
  4. Sony Cyber-shot DSC-WX350 Flash Assembly Replacement: 手順 4、 1の画像 1
    • Now take the control wheel board out with your hand.
  5. Sony Cyber-shot DSC-WX350 Flash Assembly Replacement: 手順 5、 1の画像 1
    • On the left side of the camera, pull the LCD off the back plate.
    • There will be a ZIF connector by the control wheel, release the connector and remove the LCD.
  6. Sony Cyber-shot DSC-WX350 Flash Assembly Replacement: 手順 6、 2の画像 1 Sony Cyber-shot DSC-WX350 Flash Assembly Replacement: 手順 6、 2の画像 2
    • Remove silver Phillips 4 mm screws using the J00 head screwdriver tip from the metal cover. Once done take the metal cover off with your hands.
  7. Sony Cyber-shot DSC-WX350 Flash Assembly Replacement: 手順 7、 3の画像 1 Sony Cyber-shot DSC-WX350 Flash Assembly Replacement: 手順 7、 3の画像 2 Sony Cyber-shot DSC-WX350 Flash Assembly Replacement: 手順 7、 3の画像 3
    • Using your finger open take off the three zifs.
  8. Sony Cyber-shot DSC-WX350 Flash Assembly Replacement: 手順 8、 2の画像 1 Sony Cyber-shot DSC-WX350 Flash Assembly Replacement: 手順 8、 2の画像 2
    • Use your hand to take out the lens assembly. Then take out the motherboard assembly with your hand.
  9. Sony Cyber-shot DSC-WX350 Flash Assembly Replacement: 手順 9、 3の画像 1 Sony Cyber-shot DSC-WX350 Flash Assembly Replacement: 手順 9、 3の画像 2 Sony Cyber-shot DSC-WX350 Flash Assembly Replacement: 手順 9、 3の画像 3
    • Remove the silver Phillips 4 mm screws using the J00 head screwdriver tip from the metal piece and remove the 4mm screws from the metal piece lining the lens assembly hole.
  10. Sony Cyber-shot DSC-WX350 Flash Assembly Replacement: 手順 10、 2の画像 1 Sony Cyber-shot DSC-WX350 Flash Assembly Replacement: 手順 10、 2の画像 2
    • Grab the top of the camera and take it out. Then grab the flash assembly and slide it out.
終わりに
4 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Matt Garthwaite
メンバー登録日: 05/22/17
125 ポイント
1ガイドが承認済み
チーム
IUPUI, Team S1-G1, Wilson Summer 2017 IUPUI, Team S1-G1, Wilson Summer 2017人のメンバー
IUPUI-WILSON-SU17S1G1
4 メンバー
3のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 17
今までの合計 1,637
