はじめに
The control wheel is the button that is used to switch between pictures you are viewing and change options under "Settings". If you cannot move between different pictures or you are unable to move to different options in your settings when pushing those buttons, the control wheel may be broken. This guide will walk you through how to take apart the camera and easily replace the control wheel strip.
必要な工具と部品
Begin with the battery cover closed.
Remove 6 black Phillips 4 mm screws using the Ph000 head screwdriver tip from the bottom covering.
ある他の人がこのガイドを完成しました。
