はじめに
The purpose of this guide is to replace the LCD screen. This guide will provide the necessary information to disassemble the camera, replace the screen, and to properly reassemble the components involved.
必要な工具と部品
Remove all of the 1mm screws using a Philips #000 Screwdriver.
Remover the rest of the screws (2mm) from the camera covers using a Phillips #000 Screwdriver.
Pull up on the lower end of the plate. Lift it so the plate is high enough so that the marked bump is not holding it in place.
Pull away from the camera at the end of the metal plate with the blue circuits to then remove the plate from the rest of the camera.
ある他の人がこのガイドを完成しました。
