メインコンテンツにスキップ
Sony Cyber-shot DSC-WX100 LCD Screen Replacement
必要な工具と部品
  1. Sony Cyber-shot DSC-WX100 LCD Screen Replacement, Battery: 手順 1、 1の画像 1
    • Open the flap indicated to allow access to the battery slot.
    • The gray switch indicated has to be moved to the right in order to release the flap.
  2. Sony Cyber-shot DSC-WX100 LCD Screen Replacement: 手順 2、 1の画像 1
    • If the old battery is still in the slot, then make sure the camera is turned off prior to removal.
    • If there is a battery currently in the slot, remove by first pulling downwards on the blue component. This will allow you to remove the battery from the slot.
  3. Sony Cyber-shot DSC-WX100 LCD Screen Replacement, Outer Casing: 手順 3、 3の画像 1 Sony Cyber-shot DSC-WX100 LCD Screen Replacement, Outer Casing: 手順 3、 3の画像 2 Sony Cyber-shot DSC-WX100 LCD Screen Replacement, Outer Casing: 手順 3、 3の画像 3
    • Remove all of the 1mm screws using a Philips #000 Screwdriver.
    • Remover the rest of the screws (2mm) from the camera covers using a Phillips #000 Screwdriver.
  4. Sony Cyber-shot DSC-WX100 LCD Screen Replacement: 手順 4、 2の画像 1 Sony Cyber-shot DSC-WX100 LCD Screen Replacement: 手順 4、 2の画像 2
    • Use the plastic opening tool to gently remove the front and back plates of the camera.
  5. Sony Cyber-shot DSC-WX100 LCD Screen Replacement: 手順 5、 2の画像 1 Sony Cyber-shot DSC-WX100 LCD Screen Replacement: 手順 5、 2の画像 2
    • Use a plastic opening tool to gently release the two indicated tabs.
    • Pull up on the lower end of the plate. Lift it so the plate is high enough so that the marked bump is not holding it in place.
    • Pull away from the camera at the end of the metal plate with the blue circuits to then remove the plate from the rest of the camera.
    • For help please watch the video.
  6. Sony Cyber-shot DSC-WX100 LCD Screen Replacement: 手順 7、 3の画像 1 Sony Cyber-shot DSC-WX100 LCD Screen Replacement: 手順 7、 3の画像 2 Sony Cyber-shot DSC-WX100 LCD Screen Replacement: 手順 7、 3の画像 3
    • Remove this screw (1mm) with a Phillips #000 Screwdriver.
    • Gently lift the LCD from the metal plate.
    • Remove the metal plate that was underneath the LCD screen from the camera.
  7. Sony Cyber-shot DSC-WX100 LCD Screen Replacement: 手順 8、 3の画像 1 Sony Cyber-shot DSC-WX100 LCD Screen Replacement: 手順 8、 3の画像 2 Sony Cyber-shot DSC-WX100 LCD Screen Replacement: 手順 8、 3の画像 3
    • Use the plastic opening tool to pry the black bar upwards.
    • Pull the LCD screen from out of the slot.
終わりに
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
Peter Prins
メンバー登録日: 03/19/15
262 ポイント
2のガイドは作成済み
チーム
Michigan Tech, Team 1-9, Lauer Spring 2015 Michigan Tech, Team 1-9, Lauer Spring 2015人のメンバー
MTU-LAUER-S15S1G9
2 メンバー
6のガイドは作成済み
コメント 1 件
be careful with capacitor !!! i touched it 5-10 minutes after battery was removed and felt electricity in my chest, ears… be careful :D
k.bilius - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 9
過去 30 日: 15
今までの合計 1,281
