はじめに
This guide will allow the reader to how to disassemble the DSC-WX100 and get to its image sensor.
必要な工具と部品
Remove all of the 1mm screws using a Philips #000 Screwdriver.
Remover the rest of the screws (2mm) from the camera covers using a Phillips #000 Screwdriver.
Pull up on the lower end of the plate. Lift it so that the plate is uninhibited by the indicated bump.
Pull away from the camera at the end of the metal plate with the blue circuits to then remove the plate from the rest of the camera.
2 の人々がこのガイドを完成させました。
コメント 1 件
thanks a lot very helpfull.
could you precise( in remounting phase) that it is necessary to take care of the position of the back slider (photo/pano/video) before screwing, it will avoid to dismount again…….
regards
