メインコンテンツにスキップ
Sony Cyber-shot DSC-W730 Flash Control Board Replacement
必要な工具と部品
  1. Sony Cyber-shot DSC-W730 Flash Control Board Replacement, Removing the Case: 手順 1、 3の画像 1 Sony Cyber-shot DSC-W730 Flash Control Board Replacement, Removing the Case: 手順 1、 3の画像 2 Sony Cyber-shot DSC-W730 Flash Control Board Replacement, Removing the Case: 手順 1、 3の画像 3
    • Open the battery/memory card door and remove the 6 screws (.35cm) with a Philips 000 screwdriver. There will be two screws on the left and right sides, and two on the bottom.
  2. Sony Cyber-shot DSC-W730 Flash Control Board Replacement: 手順 2、 3の画像 1 Sony Cyber-shot DSC-W730 Flash Control Board Replacement: 手順 2、 3の画像 2 Sony Cyber-shot DSC-W730 Flash Control Board Replacement: 手順 2、 3の画像 3
    • Take off the front part of the case with a plastic opening tool.
  3. Sony Cyber-shot DSC-W730 Flash Control Board Replacement: 手順 3、 2の画像 1 Sony Cyber-shot DSC-W730 Flash Control Board Replacement: 手順 3、 2の画像 2
    • Pull off the two silver side pieces on the left and right sides.
  4. Sony Cyber-shot DSC-W730 Flash Control Board Replacement: 手順 4、 2の画像 1 Sony Cyber-shot DSC-W730 Flash Control Board Replacement: 手順 4、 2の画像 2
    • Remove the main back piece. It should easily lift off.
  5. Sony Cyber-shot DSC-W730 Flash Control Board Replacement: 手順 5、 3の画像 1 Sony Cyber-shot DSC-W730 Flash Control Board Replacement: 手順 5、 3の画像 2 Sony Cyber-shot DSC-W730 Flash Control Board Replacement: 手順 5、 3の画像 3
    • Unscrew the .45cm screw located on the upper right corner on the back of the camera. Once the screw is off, use the spudger and unclip the piece holding the top down on the upper left on the front of the camera. It should lift off with ease.
  6. Sony Cyber-shot DSC-W730 Flash Control Board Replacement, LCD Control Board: 手順 6、 2の画像 1 Sony Cyber-shot DSC-W730 Flash Control Board Replacement, LCD Control Board: 手順 6、 2の画像 2
    • Flip over the control board then use tweezers to pull out the ribbon connecting the circuit board to the motherboard.
  7. Sony Cyber-shot DSC-W730 Flash Control Board Replacement, Caption/Flash Control Board: 手順 7、 3の画像 1 Sony Cyber-shot DSC-W730 Flash Control Board Replacement, Caption/Flash Control Board: 手順 7、 3の画像 2 Sony Cyber-shot DSC-W730 Flash Control Board Replacement, Caption/Flash Control Board: 手順 7、 3の画像 3
    • Once the case is off, hold down the ribbon near the LCD screen that connects the flash to the camera. While doing this, carefully lift the control board that contains the flash until the ribbon is no longer connected.
  8. Sony Cyber-shot DSC-W730 Flash Control Board Replacement: 手順 8、 1の画像 1
    • Once you have removed the piece this is what it will look like.
終わりに
作成者
3人の作成者と共同で作成されました。
Douglas Howe
メンバー登録日: 01/08/15
510 ポイント
4のガイドは作成済み
チーム
USF Tampa, Team 9-4, Blackwell Winter 2015 USF Tampa, Team 9-4, Blackwell Winter 2015人のメンバー
USFT-BLACKWELL-W15S9G4
3 メンバー
12のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 4
今までの合計 718
