はじめに
Once you have removed the cover the capacitor (a black cylinder that has 330v capacity) will be attached to the circuit board by a thin ribbon. Be careful with the ribbon.
必要な工具と部品
Open the battery/memory card door and remove the 6 screws (.35cm) with a Philips 000 screwdriver. There will be two screws on the left and right sides, and two on the bottom.
Lift the capacitor out and gently pull it away from the control board to unplug the ribbon attached to the side of the circuit board. Be careful not to bend the ribbon.
もう少しです!
終わりに
