メインコンテンツにスキップ
Sony Cyber-shot DSC-W570 LCD Screen Replacement
必要な工具と部品
  1. Sony Cyber-shot DSC-W570 LCD Screen  Replacement, Case Cover: 手順 1、 1の画像 1
    • Remove the two Phillips head, 2.93 mm long screws at the bottom of the camera.
    • Make sure the battery compartment door is in lock position.
  2. Sony Cyber-shot DSC-W570 LCD Screen  Replacement: 手順 2、 1の画像 1
    • Turn the camera sideways so the left side is fasning upwards, remove the two Phillips head, 2.93 mm screws.
  3. Sony Cyber-shot DSC-W570 LCD Screen  Replacement: 手順 3、 1の画像 1
    • Now turn the device so the opposite side is fasning upwards and remove the last two Phillips head, 2.93 mm screws.
  4. Sony Cyber-shot DSC-W570 LCD Screen  Replacement: 手順 4、 2の画像 1 Sony Cyber-shot DSC-W570 LCD Screen  Replacement: 手順 4、 2の画像 2
    • To remove the front cover, use a plastic opening tool gently pry the top cover.
    • Then gently lift the cover off.
  5. Sony Cyber-shot DSC-W570 LCD Screen  Replacement: 手順 5、 2の画像 1 Sony Cyber-shot DSC-W570 LCD Screen  Replacement: 手順 5、 2の画像 2
    • To remove the back case cover from the body.
    • First use a plastic opening tool gently pry along the side of the camera.
    • Then slowly and gently lift the cover off.
  6. Sony Cyber-shot DSC-W570 LCD Screen  Replacement, LCD Screen: 手順 6、 1の画像 1
    • These are the two cables connecting the LCD screen to the motherboard below the screen.
  7. Sony Cyber-shot DSC-W570 LCD Screen  Replacement: 手順 7、 1の画像 1
    • Remove the LCD screen from the side opppsite the battery terminals. Watch for the two cords mentioned in the previous step. These will still be connected.The side will flip up as shown in the next step.
  8. Sony Cyber-shot DSC-W570 LCD Screen  Replacement: 手順 8、 1の画像 1
    • Pull these two cords straight back to disconnect them from the respective housings. Caution: The housing do not need to be moved or adjusted in anyway. Do not pull the cords at an angle, it can destroy the cords and the housing. Pull Straight Back!
  9. Sony Cyber-shot DSC-W570 LCD Screen  Replacement: 手順 9、 1の画像 1
    • This is what the camera should look like after 2 cords and the screen have been removed. The lens cord is being held to the side for a clearer view.
終わりに
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
Thomas Plummer
メンバー登録日: 01/21/15
164 ポイント
1ガイドが承認済み
チーム
USF Tampa, Team 9-1, Brown Winter 2015 USF Tampa, Team 9-1, Brown Winter 2015人のメンバー
USFT-BROWN-W15S9G1
5 メンバー
10のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 32
今までの合計 1,100
