メインコンテンツにスキップ
Sony Cyber-shot DSC-W55 Motherboard - First Half Replacement
必要な工具と部品
  1. Sony Cyber-shot DSC-W55 Motherboard - First Half Replacement, Battery: 手順 1、 2の画像 1 Sony Cyber-shot DSC-W55 Motherboard - First Half Replacement, Battery: 手順 1、 2の画像 2
    • Slide the battery cover in the direction the arrow points.
    • Pull the battery cover towards you.
  2. Sony Cyber-shot DSC-W55 Motherboard - First Half Replacement: 手順 2、 2の画像 1 Sony Cyber-shot DSC-W55 Motherboard - First Half Replacement: 手順 2、 2の画像 2
    • Flick the blue switch for the battery to pop out.
    • Remove the battery from the camera.
  3. Sony Cyber-shot DSC-W55 Motherboard - First Half Replacement, Back Case: 手順 3、 2の画像 1 Sony Cyber-shot DSC-W55 Motherboard - First Half Replacement, Back Case: 手順 3、 2の画像 2
    • Using the Phillips #00 Screwdriver, remove the two screws from the caution panel.
    • Remove that panel.
    • Careful for falling pieces.
  4. Sony Cyber-shot DSC-W55 Motherboard - First Half Replacement: 手順 4、 2の画像 1 Sony Cyber-shot DSC-W55 Motherboard - First Half Replacement: 手順 4、 2の画像 2
    • Remove the screw with a Phillips #00 screwdriver from the left side of the camera (with '3x optical zoom' engraved on the side panel).
  5. Sony Cyber-shot DSC-W55 Motherboard - First Half Replacement: 手順 5、 1の画像 1
    • Remove the screw using the Phillips #00 screwdriver from the bottom of the camera, closest to the back cover.
  6. Sony Cyber-shot DSC-W55 Motherboard - First Half Replacement: 手順 6、 2の画像 1 Sony Cyber-shot DSC-W55 Motherboard - First Half Replacement: 手順 6、 2の画像 2
    • Gently remove the back cover.
    • It may be a bit stiff, so use some force to remove it. Proceed with caution.
  7. Sony Cyber-shot DSC-W55 Motherboard - First Half Replacement, Front Case: 手順 7、 1の画像 1
    • Remove the screw using a Phillips #00 screwdriver on the right side (where the caution panel used to be).
  8. Sony Cyber-shot DSC-W55 Motherboard - First Half Replacement: 手順 8、 3の画像 1 Sony Cyber-shot DSC-W55 Motherboard - First Half Replacement: 手順 8、 3の画像 2 Sony Cyber-shot DSC-W55 Motherboard - First Half Replacement: 手順 8、 3の画像 3
    • Remove the small screw using a Phillips #00 screwdriver on the bottom of the camera attached to the front cover.
    • Gently remove the front cover.
    • Put a little force to pop off the case. Proceed with caution.
  9. Sony Cyber-shot DSC-W55 Motherboard - First Half Replacement, Lens: 手順 9、 2の画像 1 Sony Cyber-shot DSC-W55 Motherboard - First Half Replacement, Lens: 手順 9、 2の画像 2
    • Flip the black secure locks off. Tweezers may be necessary.
    • Detach the two orange cables.
  10. Sony Cyber-shot DSC-W55 Motherboard - First Half Replacement: 手順 10、 2の画像 1 Sony Cyber-shot DSC-W55 Motherboard - First Half Replacement: 手順 10、 2の画像 2
    • Gently pull the lens container out of the camera.
  11. Sony Cyber-shot DSC-W55 Motherboard - First Half Replacement, Motherboard - First Half: 手順 11、 1の画像 1
    • Remove the black screw using a Phillips #00 Screwdriver on the motherboard.
  12. Sony Cyber-shot DSC-W55 Motherboard - First Half Replacement: 手順 12、 2の画像 1 Sony Cyber-shot DSC-W55 Motherboard - First Half Replacement: 手順 12、 2の画像 2
    • Remove the two orange cables on the top of the motherboard with tweezers.
    • Lift the motherboard out of its slot.
  13. Sony Cyber-shot DSC-W55 Motherboard - First Half Replacement: 手順 13、 2の画像 1 Sony Cyber-shot DSC-W55 Motherboard - First Half Replacement: 手順 13、 2の画像 2
    • For the AV port, detach the bottom orange cable.
    • For the LCD screen, detach the top orange cable on the right side of the motherboard.
    • For the motherboard, detach all the orange cables.
    • Careful not to damage the red, white, and black wires when lifting the board.
終わりに
ある他の人がこのガイドを完成しました。
作成者
6人の作成者と共同で作成されました。
Christopher Wakamatsu
メンバー登録日: 10/11/10
111 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 9-20, Regan Fall 2010 Cal Poly, Team 9-20, Regan Fall 2010人のメンバー
CPSU-REGAN-F10S9G20
5 メンバー
18のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 6
今までの合計 3,435
