はじめに
This guide shows step by step instructions to remove the lens part of the camera.
必要な工具と部品
Slide the battery cover in the direction the arrow points.
Pull the battery cover towards you.
Using the Phillips #00 Screwdriver, remove the two screws from the caution panel.
Remove that panel.
Remove the screw using a Phillips #00 screwdriver on the left side (where the "3x optical zoom" panel use to be).
15 の人々がこのガイドを完成させました。
2 件のコメント
Thanks for this guide !
unfortunatly I thinks that my lens is broken (doesn't open anymore, it may have sand inside it)
Do you know where an if I can buy a new lens ?
Thanks for info..
Need a broken lens unit as my lens cable is broken, email me if any one wants to sell a broken lens unit. at barrettoagnelo@yahoo.com
