メインコンテンツにスキップ
Sony Cyber-shot DSC-W5 Motherboard Replacement
必要な工具と部品
  1. Sony Cyber-shot DSC-W5 Motherboard Replacement, Back Cover: 手順 1、 1の画像 1
    • Remove Memory Stick Pro from the card reader slot on the bottom of the camera.
    • Remove both batteries.
  2. Sony Cyber-shot DSC-W5 Motherboard Replacement: 手順 2、 2の画像 1 Sony Cyber-shot DSC-W5 Motherboard Replacement: 手順 2、 2の画像 2
    • Remove the single visible screw from both sides of the camera.
    • Remove the two screws that are adjacent to the warning label, which is on the underside of the camera.
    • Do NOT remove all four screws from the bottom.
  3. Sony Cyber-shot DSC-W5 Motherboard Replacement: 手順 3、 2の画像 1 Sony Cyber-shot DSC-W5 Motherboard Replacement: 手順 3、 2の画像 2
    • Gently remove the back cover from the camera.
    • The first time the case is removed, it will be stiff. Be patient and gently rock the cover back and forth until it slides free.
  4. Sony Cyber-shot DSC-W5 Motherboard Replacement, LCD Screen: 手順 4、 2の画像 1 Sony Cyber-shot DSC-W5 Motherboard Replacement, LCD Screen: 手順 4、 2の画像 2
    • Remove the two screws holding the circuit board down.
  5. Sony Cyber-shot DSC-W5 Motherboard Replacement: 手順 5、 1の画像 1
    • Detach the orange cable from the board.
    • Use a thin object, like a paperclip, to gently pry the cable off the connector.
  6. Sony Cyber-shot DSC-W5 Motherboard Replacement: 手順 6、 2の画像 1 Sony Cyber-shot DSC-W5 Motherboard Replacement: 手順 6、 2の画像 2
    • The LCD screen sits in two slots; one on the bottom, and one on the left edge.
    • Slide LCD screen from the two slots.
    • Do not attempt to completely remove the screen, as it is still attached to the camera.
  7. Sony Cyber-shot DSC-W5 Motherboard Replacement: 手順 7、 3の画像 1 Sony Cyber-shot DSC-W5 Motherboard Replacement: 手順 7、 3の画像 2 Sony Cyber-shot DSC-W5 Motherboard Replacement: 手順 7、 3の画像 3
    • To remove the LCD screen, detach the orange cable from the board.
    • If needed, replace the LCD screen.
  8. Sony Cyber-shot DSC-W5 Motherboard Replacement, Speaker: 手順 8、 2の画像 1 Sony Cyber-shot DSC-W5 Motherboard Replacement, Speaker: 手順 8、 2の画像 2
    • Remove the two screws holding down the steel back plate.
    • Remove steel back plate.
  9. Sony Cyber-shot DSC-W5 Motherboard Replacement: 手順 9、 2の画像 1 Sony Cyber-shot DSC-W5 Motherboard Replacement: 手順 9、 2の画像 2
    • Now remove the plastic plate that covers the motherboard.
  10. Sony Cyber-shot DSC-W5 Motherboard Replacement: 手順 10、 2の画像 1 Sony Cyber-shot DSC-W5 Motherboard Replacement: 手順 10、 2の画像 2
    • Warning: Electric Shock From this point on, hold the camera by the chrome edges ONLY. Capacitors store electric charge even if the batteries are removed.
    • Remove the blue cable.
  11. Sony Cyber-shot DSC-W5 Motherboard Replacement: 手順 11、 2の画像 1 Sony Cyber-shot DSC-W5 Motherboard Replacement: 手順 11、 2の画像 2
    • Disconnect the flash cable (black and white wires) before completely removing the front case.
    • Gently start to remove the case.
    • Once the cable is free, set aside the front case.
  12. Sony Cyber-shot DSC-W5 Motherboard Replacement: 手順 12、 2の画像 1 Sony Cyber-shot DSC-W5 Motherboard Replacement: 手順 12、 2の画像 2
    • The speaker should now be clearly seen on the underside of the camera.
    • Gently unplug the speaker from the motherboard.
    • Replace the speaker.
  13. Sony Cyber-shot DSC-W5 Motherboard Replacement, Battery Terminal: 手順 13、 2の画像 1 Sony Cyber-shot DSC-W5 Motherboard Replacement, Battery Terminal: 手順 13、 2の画像 2
    • Remove the orange cable connecting the battery terminal to the motherboard.
  14. Sony Cyber-shot DSC-W5 Motherboard Replacement: 手順 14、 1の画像 1
    • The battery terminal is now free from the board and can be slid out.
  15. Sony Cyber-shot DSC-W5 Motherboard Replacement, Lens: 手順 15、 3の画像 1 Sony Cyber-shot DSC-W5 Motherboard Replacement, Lens: 手順 15、 3の画像 2 Sony Cyber-shot DSC-W5 Motherboard Replacement, Lens: 手順 15、 3の画像 3
    • Detach two cables that go from the motherboard to the lens.
    • Remove lens.
  16. Sony Cyber-shot DSC-W5 Motherboard Replacement, Motherboard: 手順 16、 1の画像 1
    • After the lens is detached, you can replace the motherboard.
終わりに
2 の人々がこのガイドを完成させました。
作成者
6人の作成者と共同で作成されました。
Thomas
メンバー登録日: 04/14/10
133 ポイント
6のガイドは作成済み
チーム
Cal Poly, Team 15-50, Garner Spring 2010 Cal Poly, Team 15-50, Garner Spring 2010人のメンバー
CPSU-GARNER-S10S15G50
5 メンバー
12のガイドは作成済み
コメント 1 件
Thank yo very much, Muy agradecido por la información. Good information fireman4792000@yahoo.com
Jorge - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 23
今までの合計 5,700
