Remove the single visible screw from both sides of the camera.
Remove the two screws that are adjacent to the warning label, which is on the underside of the camera.
Do NOT remove all four screws from the bottom.
Gently remove the back cover from the camera.
The first time the case is removed, it will be stiff. Be patient and gently rock the cover back and forth until it slides free.
Detach the orange cable from the board.
Use a thin object, like a paperclip, to gently pry the cable off the connector.
The LCD screen sits in two slots; one on the bottom, and one on the left edge.
Slide LCD screen from the two slots.
Do not attempt to completely remove the screen, as it is still attached to the camera.
To remove the LCD screen, detach the orange cable from the board.
If needed, replace the LCD screen.
Disconnect the flash cable (black and white wires) before completely removing the front case.
Gently start to remove the case.
Once the cable is free, set aside the front case.
このガイドを埋め込む
サイズを選択し、以下のコードをコピーして、このガイドを小さなウィジェットとしてサイト/フォーラムに埋め込みます。
1つの手順
全ガイド
小サイズ - 600px
中サイズ - 800px
大サイズ - 1200px
プレビュー
