メインコンテンツにスキップ
Sony Cyber-shot DSC-W5 Lens Replacement
必要な工具と部品
  1. Sony Cyber-shot DSC-W5 Lens Replacement, Back Cover: 手順 1、 1の画像 1
    • Remove Memory Stick Pro from the card reader slot on the bottom of the camera.
    • Remove both batteries.
  2. Sony Cyber-shot DSC-W5 Lens Replacement: 手順 2、 2の画像 1 Sony Cyber-shot DSC-W5 Lens Replacement: 手順 2、 2の画像 2
    • Remove the single visible screw from both sides of the camera.
    • Remove the two screws that are adjacent to the warning label, which is on the underside of the camera.
    • Do NOT remove all four screws from the bottom.
  3. Sony Cyber-shot DSC-W5 Lens Replacement: 手順 3、 2の画像 1 Sony Cyber-shot DSC-W5 Lens Replacement: 手順 3、 2の画像 2
    • Gently remove the back cover from the camera.
    • The first time the case is removed, it will be stiff. Be patient and gently rock the cover back and forth until it slides free.
  4. Sony Cyber-shot DSC-W5 Lens Replacement, LCD Screen: 手順 4、 2の画像 1 Sony Cyber-shot DSC-W5 Lens Replacement, LCD Screen: 手順 4、 2の画像 2
    • Remove the two screws holding the circuit board down.
    what to do if i cannot remove the screws
    aarushi salunkhe - 返信
  5. Sony Cyber-shot DSC-W5 Lens Replacement: 手順 5、 1の画像 1
    • Detach the orange cable from the board.
    • Use a thin object, like a paperclip, to gently pry the cable off the connector.
  6. Sony Cyber-shot DSC-W5 Lens Replacement: 手順 6、 2の画像 1 Sony Cyber-shot DSC-W5 Lens Replacement: 手順 6、 2の画像 2
    • The LCD screen sits in two slots; one on the bottom, and one on the left edge.
    • Slide LCD screen from the two slots.
    • Do not attempt to completely remove the screen, as it is still attached to the camera.
  7. Sony Cyber-shot DSC-W5 Lens Replacement: 手順 7、 3の画像 1 Sony Cyber-shot DSC-W5 Lens Replacement: 手順 7、 3の画像 2 Sony Cyber-shot DSC-W5 Lens Replacement: 手順 7、 3の画像 3
    • To remove the LCD screen, detach the orange cable from the board.
    • If needed, replace the LCD screen.
  8. Sony Cyber-shot DSC-W5 Lens Replacement, Speaker: 手順 8、 2の画像 1 Sony Cyber-shot DSC-W5 Lens Replacement, Speaker: 手順 8、 2の画像 2
    • Remove the two screws holding down the steel back plate.
    • Remove steel back plate.
  9. Sony Cyber-shot DSC-W5 Lens Replacement: 手順 9、 2の画像 1 Sony Cyber-shot DSC-W5 Lens Replacement: 手順 9、 2の画像 2
    • Now remove the plastic plate that covers the motherboard.
    Below and to the left of the viewfinder there is a vertical slot in the motherboard with a soldered connection to the flash capacitor on each side. Using a small screwdriver with an INSULATED handle, short these together for several seconds to discharge the potentially dangerous charge.
    Philip Le Riche - 返信
  10. Sony Cyber-shot DSC-W5 Lens Replacement: 手順 10、 2の画像 1 Sony Cyber-shot DSC-W5 Lens Replacement: 手順 10、 2の画像 2
    • Warning: Electric Shock From this point on, hold the camera by the chrome edges ONLY. Capacitors store electric charge even if the batteries are removed.
    • Remove the blue cable.
  11. Sony Cyber-shot DSC-W5 Lens Replacement: 手順 11、 2の画像 1 Sony Cyber-shot DSC-W5 Lens Replacement: 手順 11、 2の画像 2
    • Disconnect the flash cable (black and white wires) before completely removing the front case.
    • Gently start to remove the case.
    • Once the cable is free, set aside the front case.
    If the front doesn't seem to want to come away, maybe the flash cable is caught around its socket.
  12. Sony Cyber-shot DSC-W5 Lens Replacement: 手順 12、 2の画像 1 Sony Cyber-shot DSC-W5 Lens Replacement: 手順 12、 2の画像 2
    • The speaker should now be clearly seen on the underside of the camera.
    • Gently unplug the speaker from the motherboard.
    • Replace the speaker.
  13. Sony Cyber-shot DSC-W5 Lens Replacement, Battery Terminal: 手順 13、 2の画像 1 Sony Cyber-shot DSC-W5 Lens Replacement, Battery Terminal: 手順 13、 2の画像 2
    • Remove the orange cable connecting the battery terminal to the motherboard.
  14. Sony Cyber-shot DSC-W5 Lens Replacement: 手順 14、 1の画像 1
    • The battery terminal is now free from the board and can be slid out.
  15. Sony Cyber-shot DSC-W5 Lens Replacement, Lens: 手順 15、 3の画像 1 Sony Cyber-shot DSC-W5 Lens Replacement, Lens: 手順 15、 3の画像 2 Sony Cyber-shot DSC-W5 Lens Replacement, Lens: 手順 15、 3の画像 3
    • Detach two cables that go from the motherboard to the lens.
    • Remove lens.
終わりに
7 の人々がこのガイドを完成させました。
作成者
6人の作成者と共同で作成されました。
Thomas
メンバー登録日: 04/14/10
133 ポイント
6のガイドは作成済み
チーム
Cal Poly, Team 15-50, Garner Spring 2010 Cal Poly, Team 15-50, Garner Spring 2010人のメンバー
CPSU-GARNER-S10S15G50
5 メンバー
12のガイドは作成済み
コメント 1 件
Ifixit it's so awesome... For a guy who loves to bring things apart but is scared of how to do it ifixit is wonderful
ogunkayodesamuel - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 28
今までの合計 21,668
