Remove the single visible screw from both sides of the camera.
Remove the two screws that are adjacent to the warning label, which is on the underside of the camera.
Do NOT remove all four screws from the bottom.
Gently remove the back cover from the camera.
The first time the case is removed, it will be stiff. Be patient and gently rock the cover back and forth until it slides free.
Detach the orange cable from the board.
Use a thin object, like a paperclip, to gently pry the cable off the connector.
The LCD screen sits in two slots; one on the bottom, and one on the left edge.
Slide LCD screen from the two slots.
Do not attempt to completely remove the screen, as it is still attached to the camera.
To remove the LCD screen, detach the orange cable from the board.
If needed, replace the LCD screen.
このガイドを埋め込む
サイズを選択し、以下のコードをコピーして、このガイドを小さなウィジェットとしてサイト/フォーラムに埋め込みます。
プレビュー
