メインコンテンツにスキップ
Sony Cyber-shot DSC-W230 LCD Display Screen Replacement
必要な工具と部品
  1. Sony Cyber-shot DSC-W230 LCD Display Screen Replacement, Separating Camera and Display: 手順 1、 2の画像 1 Sony Cyber-shot DSC-W230 LCD Display Screen Replacement, Separating Camera and Display: 手順 1、 2の画像 2
    • Align the camera so that the side with "4x Optical Zoom" is facing toward you.
    • Gently twist the bottom corner clockwise until you feel the side panel unlock.
    • Lift off the side panel and set aside.
  2. Sony Cyber-shot DSC-W230 LCD Display Screen Replacement: 手順 2、 2の画像 1 Sony Cyber-shot DSC-W230 LCD Display Screen Replacement: 手順 2、 2の画像 2
    • Rotate the camera 180 degrees to face the side panel with the lanyard loop on it.
    • Gently lift the panel vertically until it lifts off
    • Take care to not lose the small rectangular portion on the bottom of the panel.
  3. Sony Cyber-shot DSC-W230 LCD Display Screen Replacement: 手順 3、 3の画像 1 Sony Cyber-shot DSC-W230 LCD Display Screen Replacement: 手順 3、 3の画像 2 Sony Cyber-shot DSC-W230 LCD Display Screen Replacement: 手順 3、 3の画像 3
    • Position the camera so the bottom is facing up and the display away from the surface.
    • Gently pry the screen portion from the camera portion with your fingers or a plastic prybar.
    • Do not fully separate the two components! the screen is attached by two ribbon cables.
    • Lay the display flat to expose the circuit board and the display control ribbon cables.
  4. Sony Cyber-shot DSC-W230 LCD Display Screen Replacement, LCD Display Screen: 手順 4、 1の画像 1
    • Using a flat head screw driver gently pry up the tab securing the ribbon cable from the display screen to the camera sensor and battery housing.
    • Remove the ribbon cable connecting LCD display to camera sensor and battery housing
    • Following the same procedure as above, uninstall the ribbon cable connecting the main camera controls to the camera sensor and battery housing
  5. Sony Cyber-shot DSC-W230 LCD Display Screen Replacement: 手順 5、 1の画像 1
    • The LCD display screen is now removed from the camera sensor and battery housing.
    • The main camera controls are now removed from the camera sensor and battery housing.
  6. Sony Cyber-shot DSC-W230 LCD Display Screen Replacement: 手順 6、 1の画像 1
    • Unsnap LCD display screen from its mount by unsnapping it from the display screen using your finger nail.
    • Now the new LCD screen can be installed.
終わりに
2 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Michael Henry
メンバー登録日: 03/09/12
21 ポイント
1ガイドが承認済み
チーム
Clemson, Team 2-3, Benson Spring 2012 Clemson, Team 2-3, Benson Spring 2012人のメンバー
CLEM-BENSON-S12S2G3
3 メンバー
11のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 10
過去 7 日: 17
過去 30 日: 43
今までの合計 3,876
