はじめに
This guide will explain how to take the necessary components of the camera apart in order to replace a damaged LCD display screen.
必要な工具と部品
Align the camera so that the side with "4x Optical Zoom" is facing toward you.
Gently twist the bottom corner clockwise until you feel the side panel unlock.
Lift off the side panel and set aside.
Using a flat head screw driver gently pry up the tab securing the ribbon cable from the display screen to the camera sensor and battery housing.
Remove the ribbon cable connecting LCD display to camera sensor and battery housing
Following the same procedure as above, uninstall the ribbon cable connecting the main camera controls to the camera sensor and battery housing
2 の人々がこのガイドを完成させました。
