On the right side of the camera, remove the two silver screws using the screwdriver.
The picture shows the lens facing away from you and the LCD screen facing you.
On the left side of the camera, remove the two silver screws using the screwdriver.
Keep track of the small screws that you remove.
Opening, removing, and/or replacing the front casing may void your manufacturer's warranty.
After popping open the plastic piece, there is a screw that needs to be removed.
Remove the screw connecting the front casing to the electrical components.
On the casing on the opposite side of the camera, gently loosen and remove the casing by firmly pulling with your fingers.
Be cautious not to break the fragile pieces or scratch the LCD screen.
このガイドを埋め込む
サイズを選択し、以下のコードをコピーして、このガイドを小さなウィジェットとしてサイト/フォーラムに埋め込みます。
プレビュー
