はじめに
This page will guide you through the removal of the front casing on the Sony Cyber-shot DSC W150.
パーツ
パーツは必要ありません。
  1. The screws from the camera are extremely small so it is a good idea to have a small container to hold all the screws as you remove them.
    • The screws from the camera are extremely small so it is a good idea to have a small container to hold all the screws as you remove them.
  2. Take your screwdriver and remove the bottom screws of the camera. (The picture shows the lens facing away from you and the LCD facing you.) There should be four silver screws.
    • Take your screwdriver and remove the bottom screws of the camera. (The picture shows the lens facing away from you and the LCD facing you.) There should be four silver screws.
  3. On the right side of the camera, remove the two screws using the screwdriver. There will be two silver screws. (The picture shows the lens facing away from you and LCD screen facing you.)
    • On the right side of the camera, remove the two screws using the screwdriver. There will be two silver screws. (The picture shows the lens facing away from you and LCD screen facing you.)
  4. On the left side of the camera, remove the two screws using the screwdriver. There will be two silver screws. (The picture shows the lens facing away from you and the LCD screen facing you.)
    • On the left side of the camera, remove the two screws using the screwdriver. There will be two silver screws. (The picture shows the lens facing away from you and the LCD screen facing you.)
  5. Gently remove the back casing by holding onto both sides of the camera and pulling them apart.
    • Gently remove the back casing by holding onto both sides of the camera and pulling them apart.
  6. Pro Tech ツールキットを含むご注文、もしくは総額 $100ドル以上のご注文については送料無料です。
    当社のショップを閲覧する
  7. Now, carefully pull off the back cover.
    • Now, carefully pull off the back cover.
  8. The two halves of the camera casing should now be separate.
    • The two halves of the camera casing should now be separate.
  9. Keep track of the small screws that you remove.
    • Keep track of the small screws that you remove.
    • Opening, removing and/or replacing the front casing may void your manufacturers warranty
  10. Remove the two screws at the top of the camera casing.
    • Remove the two screws at the top of the camera casing.
  11. Gently pop open the plastic piece as shown.
    • Gently pop open the plastic piece as shown.
  12. Remove the screw connecting the front casing to the electrical components as shown.
    • Remove the screw connecting the front casing to the electrical components as shown.
  13. Gently loosen and remove the side casing by firmly pulling with your fingers.
    • Gently loosen and remove the side casing by firmly pulling with your fingers.
    • Take care not to break the fragile part or to scratch the LCD screen.
  14. Remove the two screws connecting the front casing to the electrical components.
    • Remove the two screws connecting the front casing to the electrical components.
  15. Gently loosen the front casing.
    • Gently loosen the front casing.
    • Be careful not to scratch any of the exposed electrical components.
  16. Fully remove the front casing from the camera.
    • Fully remove the front casing from the camera.
まとめ
5 の人々がこのガイドを完成させました。
Julio Maravilla
メンバー登録日: 2010年04月15日
191 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 33-73, Johann Spring 2010 Cal Poly, Team 33-73, Johann Spring 2010人のメンバー
CPSU-JOHANN-S10S33G73
3 メンバー
2のガイドは作成済み
コメントを追加する
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 5,727
