メインコンテンツにスキップ
Sony Cyber-shot DSC-TX7 Front Sliding Lens Cover Replacement
必要な工具と部品
  1. Sony Cyber-shot DSC-TX7 Front Sliding Lens Cover Replacement, Battery: 手順 1、 2の画像 1 Sony Cyber-shot DSC-TX7 Front Sliding Lens Cover Replacement, Battery: 手順 1、 2の画像 2
    • The battery compartment is located on the bottom of camera.
    • Move the slider from the 'lock' position to the 'open' position.
  2. Sony Cyber-shot DSC-TX7 Front Sliding Lens Cover Replacement: 手順 2、 3の画像 1 Sony Cyber-shot DSC-TX7 Front Sliding Lens Cover Replacement: 手順 2、 3の画像 2 Sony Cyber-shot DSC-TX7 Front Sliding Lens Cover Replacement: 手順 2、 3の画像 3
    • Battery not shown.
    • Pull battery from compartment.
    • Insert newly charged battery into compartment, as shown in diagram (located in compartment).
    • Shut compartment door.
    • Move the slider back to the 'lock' position.
  3. Sony Cyber-shot DSC-TX7 Front Sliding Lens Cover Replacement, Front Cover: 手順 3、 1の画像 1
    • Use the Phillips #00 screwdriver to remove the 4mm length screws. There are 6 screws total.
  4. Sony Cyber-shot DSC-TX7 Front Sliding Lens Cover Replacement: 手順 4、 3の画像 1 Sony Cyber-shot DSC-TX7 Front Sliding Lens Cover Replacement: 手順 4、 3の画像 2 Sony Cyber-shot DSC-TX7 Front Sliding Lens Cover Replacement: 手順 4、 3の画像 3
    • The 4 mm length screws are located on each side and on the bottom of the camera.
    • 2 screws on each side (4 total).
    • 2 screws on bottom.
  5. Sony Cyber-shot DSC-TX7 Front Sliding Lens Cover Replacement: 手順 5、 1の画像 1
    • Gently pry around the front cover using the plastic opening tool.
    • Carefully separate front cover from body of camera.
  6. Sony Cyber-shot DSC-TX7 Front Sliding Lens Cover Replacement: 手順 6、 1の画像 1
    • The front cover is now removed from the camera and the internal hardware is now visible.
    • They front cover will still be connected by a ribbon. Be careful not to break the ribbon.
  7. Sony Cyber-shot DSC-TX7 Front Sliding Lens Cover Replacement, Front Sliding Lens Cover: 手順 7、 2の画像 1 Sony Cyber-shot DSC-TX7 Front Sliding Lens Cover Replacement, Front Sliding Lens Cover: 手順 7、 2の画像 2
    • Remove the three 4mm length screws located on the inside of the front cover with the Phillips #00 screwdriver.
  8. Sony Cyber-shot DSC-TX7 Front Sliding Lens Cover Replacement: 手順 8、 2の画像 1 Sony Cyber-shot DSC-TX7 Front Sliding Lens Cover Replacement: 手順 8、 2の画像 2
    • Wiggle sliding lens cover after all screws are removed and separate from front cover.
終わりに
作成者
2人の作成者と共同で作成されました。
Leslie Mundell
メンバー登録日: 03/18/15
411 ポイント
4のガイドは作成済み
チーム
Michigan Tech, Team 1-8, Lauer Spring 2015 Michigan Tech, Team 1-8, Lauer Spring 2015人のメンバー
MTU-LAUER-S15S1G8
2 メンバー
10のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 20
今までの合計 675
