メインコンテンツにスキップ
Sony Cyber-shot DSC-TX100V OLED/LCD Assembly Replacement
必要な工具と部品
  1. Sony Cyber-shot DSC-TX100V OLED/LCD Assembly Replacement, OLED/LCD Assembly: 手順 1、 3の画像 1 Sony Cyber-shot DSC-TX100V OLED/LCD Assembly Replacement, OLED/LCD Assembly: 手順 1、 3の画像 2 Sony Cyber-shot DSC-TX100V OLED/LCD Assembly Replacement, OLED/LCD Assembly: 手順 1、 3の画像 3
    • Remove the battery
    • Remove the five 2.5mm Philips #0 screws.
    • Remove the one 2.5mm Philips #0 screw inside the HDMI case.
  2. Sony Cyber-shot DSC-TX100V OLED/LCD Assembly Replacement: 手順 2、 1の画像 1
    • Gently work and pull the front cover off of the camera
  3. Sony Cyber-shot DSC-TX100V OLED/LCD Assembly Replacement: 手順 3、 1の画像 1
    • Gently pull and disconnect the ribbon cable connecting the front cover to the main body
  4. Sony Cyber-shot DSC-TX100V OLED/LCD Assembly Replacement: 手順 4、 3の画像 1 Sony Cyber-shot DSC-TX100V OLED/LCD Assembly Replacement: 手順 4、 3の画像 2 Sony Cyber-shot DSC-TX100V OLED/LCD Assembly Replacement: 手順 4、 3の画像 3
    この手順で使用する道具:
    iSesamo Opening Tool
    $9.99
    購入する
    • Using an iSesamo Opening Tool, Spudger, or flat dull opening tool, gently pry off the cover of the OLED/LCD assembly.
    • Take care of the tab/clip at the bottom, it can be a little tricky.
    • iSesamo Opening Tool is highly recommended
  5. Sony Cyber-shot DSC-TX100V OLED/LCD Assembly Replacement: 手順 5、 2の画像 1 Sony Cyber-shot DSC-TX100V OLED/LCD Assembly Replacement: 手順 5、 2の画像 2
    • Remove the copper phillips screw holding the HDMI mounting plate and detach the mounting plate.
  6. Sony Cyber-shot DSC-TX100V OLED/LCD Assembly Replacement: 手順 6、 3の画像 1 Sony Cyber-shot DSC-TX100V OLED/LCD Assembly Replacement: 手順 6、 3の画像 2 Sony Cyber-shot DSC-TX100V OLED/LCD Assembly Replacement: 手順 6、 3の画像 3
    この手順で使用する道具:
    $9.99
    購入する
    • Using an iSesamo Opening Tool, Spudger, or flat dull opening tool, gently pry the OLED/LCD assembly from the adhesive strip on the main body.
    • Note: where the adhesive strip is located.
    • Turn the device over and remove the clear tape and black tape.
    • Important: Save the clear and black tape, they will be used for the replacement unit.
  7. Sony Cyber-shot DSC-TX100V OLED/LCD Assembly Replacement: 手順 7、 1の画像 1
    • Gently pull the small flat ribbon cable from the main body
    • In order to disconnect the large flat ribbon cable, you need to flip up the black ribbon clamp located on the main body where the socket is located
  8. Sony Cyber-shot DSC-TX100V OLED/LCD Assembly Replacement: 手順 8、 1の画像 1
    • Reattach new display, and reconnect all components
    • Test camera to ensure the new screen is working
    • Congrats!
終わりに
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
Tim
メンバー登録日: 03/12/12
2,163 ポイント
2のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 8
過去 30 日: 34
今までの合計 4,396
