必要な工具と部品
Remove the battery
Remove the five 2.5mm Philips #0 screws.
Remove the one 2.5mm Philips #0 screw inside the HDMI case.
Using an iSesamo Opening Tool, Spudger, or flat dull opening tool, gently pry off the cover of the OLED/LCD assembly.
Take care of the tab/clip at the bottom, it can be a little tricky.
iSesamo Opening Tool is highly recommended
Using an iSesamo Opening Tool, Spudger, or flat dull opening tool, gently pry the OLED/LCD assembly from the adhesive strip on the main body.
Note: where the adhesive strip is located.
Turn the device over and remove the clear tape and black tape.
Important: Save the clear and black tape, they will be used for the replacement unit.
ある他の人がこのガイドを完成しました。
