メインコンテンツにスキップ
Sony Cyber-shot DSC-T9 LCD Replacement
必要な工具と部品
  1. Sony Cyber-shot DSC-T9 LCD Replacement, Battery: 手順 1、 1の画像 1
    • The battery cover is located on the right side of the camera.
    • Slide the cover to expose the battery.
  2. Sony Cyber-shot DSC-T9 LCD Replacement: 手順 2、 1の画像 1
    • Ensure that the battery lines up properly with the slot in the camera.
    • Slide battery in.
    • Slide cover closed.
    • Battery not shown
  3. Sony Cyber-shot DSC-T9 LCD Replacement, Front Cover: 手順 3、 3の画像 1 Sony Cyber-shot DSC-T9 LCD Replacement, Front Cover: 手順 3、 3の画像 2 Sony Cyber-shot DSC-T9 LCD Replacement, Front Cover: 手順 3、 3の画像 3
    • Remove screws from outside of camera. There are 6 screws total.
    • 3 screws on underside.
    • 1 screw on right side, near battery cover.
    • 2 screws on left side.
  4. Sony Cyber-shot DSC-T9 LCD Replacement: 手順 4、 1の画像 1
    • Use screwdriver to remove screws.
  5. Sony Cyber-shot DSC-T9 LCD Replacement: 手順 5、 1の画像 1
    • Gently pull the front cover off of the main camera.
    • All of the inner parts of the camera are attached to the back screen.
  6. Sony Cyber-shot DSC-T9 LCD Replacement: 手順 6、 1の画像 1
    • The front cover is now removed from the camera and the internal hardware is now exposed.
  7. Sony Cyber-shot DSC-T9 LCD Replacement, Back Cover: 手順 7、 1の画像 1
    • This is the camera without the front cover.
  8. Sony Cyber-shot DSC-T9 LCD Replacement: 手順 8、 1の画像 1
    • Remove tripod piece located at the bottom of the camera. This piece should slide out with ease.
  9. Sony Cyber-shot DSC-T9 LCD Replacement: 手順 9、 3の画像 1 Sony Cyber-shot DSC-T9 LCD Replacement: 手順 9、 3の画像 2 Sony Cyber-shot DSC-T9 LCD Replacement: 手順 9、 3の画像 3
    • Slide open the top panel. This is located on the top of the camera, where the power button and shutter button are.
  10. Sony Cyber-shot DSC-T9 LCD Replacement: 手順 10、 3の画像 1 Sony Cyber-shot DSC-T9 LCD Replacement: 手順 10、 3の画像 2 Sony Cyber-shot DSC-T9 LCD Replacement: 手順 10、 3の画像 3
    • Pull apart the inner hardware from the back case by prying on the left side.
  11. Sony Cyber-shot DSC-T9 LCD Replacement: 手順 11、 1の画像 1
    • Remove the back cover.
  12. Sony Cyber-shot DSC-T9 LCD Replacement: 手順 12、 1の画像 1
    • The back cover is now removed from the internal hardware.
  13. Sony Cyber-shot DSC-T9 LCD Replacement, LCD: 手順 13、 1の画像 1
    • Use the spudger to pry the LCD from the camera.
  14. Sony Cyber-shot DSC-T9 LCD Replacement: 手順 14、 1の画像 1
    • The LCD is now removed from the camera, although attached by a ribbon at the bottom of the camera.
  15. Sony Cyber-shot DSC-T9 LCD Replacement: 手順 15、 2の画像 1 Sony Cyber-shot DSC-T9 LCD Replacement: 手順 15、 2の画像 2
    • Flip camera to other side.
    • Use tweezers to peel off black sticker, located in middle of the motherboard.
  16. Sony Cyber-shot DSC-T9 LCD Replacement: 手順 16、 2の画像 1 Sony Cyber-shot DSC-T9 LCD Replacement: 手順 16、 2の画像 2
    • Use pry stick to pop out LCD connector ribbon, also called the ZIF connector.
  17. Sony Cyber-shot DSC-T9 LCD Replacement: 手順 17、 1の画像 1
    • The LCD is now removed from the camera.
終わりに
ある他の人がこのガイドを完成しました。
作成者
4人の作成者と共同で作成されました。
Stephannie Allen
メンバー登録日: 03/11/13
255 ポイント
10のガイドは作成済み
チーム
Clemson, Team 13-1, Benson Spring 2013 Clemson, Team 13-1, Benson Spring 2013人のメンバー
CLEM-BENSON-S13S13G1
4 メンバー
20のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 12
過去 30 日: 23
今までの合計 1,161
