この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
Taking out the LCD is one of the more difficult things to do on your Cyber-shot. Because the LCD is located at the back of the camera you will have to take apart the entire camera just to reach it.
必要な工具と部品
Locate the battery door at the bottom of the camera.
Press down on the door and slide it back. The door will pop open.
Use a PH00 screwdriver and remove the six 2.9mm screws.
Use the tip of a spudger to flip up the tab on the ZIF connector securing the motherboard ribbon cable.
The second picture shows what these tabs look like in their open positions.
Use tweezers to slide the white piece on the back of the back cover to the right.
This will dislodge the white piece, allowing you to remove it from the back cover.
