メインコンテンツにスキップ
修理を始めるには
修理する権利
パーツ&ツール
パーツ
パーツは指定されていません。
  1. Slide the battery latch down the side of the camera with your hands.
    • Slide the battery latch down the side of the camera with your hands.
    • The latch will automatically pop open.
  2. Unlatch the clip over the battery.
    • Unlatch the clip over the battery.
    • The battery will partially pop out.
  3. Remove the battery from the camera. Remove the battery from the camera.
    • Remove the battery from the camera.
  4. Unscrew the four 3.0mm Phillips #000 screws holding the back case onto the camera; there are two screws on top and two on the bottom.
    • Unscrew the four 3.0mm Phillips #000 screws holding the back case onto the camera; there are two screws on top and two on the bottom.
  5. Pull the back case gently away from the rest of the camera. Pull the back case gently away from the rest of the camera.
    • Pull the back case gently away from the rest of the camera.
  6. Remove the two 3.0mm Phillips #000 screws holding the display to the metal backing.
    • Remove the two 3.0mm Phillips #000 screws holding the display to the metal backing.
  7. Unlatch the display by sliding it towards the circuit board. Unlatch the display by sliding it towards the circuit board.
    • Unlatch the display by sliding it towards the circuit board.
  8. Remove the two ribbon cables attached to the circuit board by gently pulling them out of their slots.
    • Remove the two ribbon cables attached to the circuit board by gently pulling them out of their slots.
    • Be careful not to rip the ribbon cables while disconnecting them.
  9. The LCD is now separated from the camera.
    • The LCD is now separated from the camera.
終わりに
Jenna Crawford
メンバー登録日: 2012年04月09日
29 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team 17-25, Amido Spring 2012 Cal Poly, Team 17-25, Amido Spring 2012人のメンバー
CPSU-AMIDO-S12S17G25
4 メンバー
7のガイドは作成済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 741
