メインコンテンツにスキップ
Sony Cyber-shot DSC-P52 LCD Replacement
必要な工具と部品
  1. Sony Cyber-shot DSC-P52 LCD Replacement, Outer Case: 手順 1、 1の画像 1
    • Open the battery compartment and remove the batteries.
    • Remove all of the visible screws on the outside of the case.
    • There should be three of them that are all easily located.
  2. Sony Cyber-shot DSC-P52 LCD Replacement: 手順 2、 1の画像 1
    • Open the memory card compartment.
    • Remove the screw next to the memory card slot.
  3. Sony Cyber-shot DSC-P52 LCD Replacement: 手順 3、 1の画像 1
    • Pull apart the front and back cover pieces carefully.
    • The front cover should come completely free with little effort.
    • The back cover will still be attached to the circuit board.
  4. Sony Cyber-shot DSC-P52 LCD Replacement: 手順 4、 1の画像 1
    • Simultaneously unclip all of the clips holding in the circuitry. Remove the back case.
    • The circuitry will still be connected to the back case by ribbon cables.
  5. Sony Cyber-shot DSC-P52 LCD Replacement: 手順 5、 1の画像 1
    • Open the case as shown.
  6. Sony Cyber-shot DSC-P52 LCD Replacement: 手順 6、 1の画像 1
    • Unclip the clip holding the ribbon cable in.
    • Other ribbon cables might not have a clips.
  7. Sony Cyber-shot DSC-P52 LCD Replacement: 手順 7、 1の画像 1
    • Pull the ribbon cable out.
  8. Sony Cyber-shot DSC-P52 LCD Replacement, Sony Cyber-shot DSC-P52 Removing Ribbon Cables: 手順 8、 1の画像 1
    • Unclip the ribbon cable shown the in picture.
    • Some ribbon cables do not have a clip holding them in.
  9. Sony Cyber-shot DSC-P52 LCD Replacement: 手順 9、 1の画像 1
  10. Sony Cyber-shot DSC-P52 LCD Replacement, LCD: 手順 10、 1の画像 1
    • Remove 7 Screws to remove plate and expose LCD screen.
  11. Sony Cyber-shot DSC-P52 LCD Replacement: 手順 11、 1の画像 1
    • Remove LCD plate to expose LCD components and ribbon cables
  12. Sony Cyber-shot DSC-P52 LCD Replacement: 手順 12、 1の画像 1
    • Check connection of LCD to cables
    • If cables are intact, disconnect cables and replace LCD with new part
  13. Sony Cyber-shot DSC-P52 LCD Replacement: 手順 13、 1の画像 1
    • Repeat steps in reverse order to reassemble the camera
終わりに
作成者
6人の作成者と共同で作成されました。
Mark
メンバー登録日: 01/11/11
13 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 3-43, Regan Winter 2011 Cal Poly, Team 3-43, Regan Winter 2011人のメンバー
CPSU-REGAN-W11S3G43
4 メンバー
20のガイドは作成済み
コメント 1 件
I don’t know the cause of my camera not turning on.
Smgmc64 Productions - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 3
今までの合計 2,483
