Open the battery compartment and remove the batteries.
Remove all of the visible screws on the outside of the case.
There should be three of them that are all easily located.
Pull apart the front and back cover pieces carefully.
The front cover should come completely free with little effort.
The back cover will still be attached to the circuit board.
Remove all six screws on the front side of the motherboard circled in the picture.
Pull the motherboard from the rest of the housing.
It will still be connected to the flash unit.
Detach the ribbon cables shown.
Careful! Touching the leads of the large yellow capacitor can result in a painful shock.
Remove the flash unit from the motherboard.
Discharge the yellow capacitor attached to the flash unit by shorting the leads with a screw driver.
Avoid touching the leads with your hands, as this can result in a painful shock.
このガイドを埋め込む
サイズを選択し、以下のコードをコピーして、このガイドを小さなウィジェットとしてサイト/フォーラムに埋め込みます。
プレビュー
