メインコンテンツにスキップ
修理を始めるには
修理する権利
パーツ&ツール
はじめに
If buttons are unresponsive, they may require cleaning. This guide will go through the procedure of button cleaning.
  1. Open the battery compartment and remove the batteries.
    • Open the battery compartment and remove the batteries.
    • Remove all of the visible screws on the outside of the case.
    • There should be three of them that are all easily located.
  2. Open the memory card compartment.
    • Open the memory card compartment.
    • Remove the screw next to the memory card slot.
  3. Pull apart the front and back cover pieces carefully.
    • Pull apart the front and back cover pieces carefully.
    • The front cover should come completely free with little effort.
    • The back cover will still be attached to the circuit board.
  4. Simultaneously unclip all of the clips holding in the circuitry. Remove the back case.
    • Simultaneously unclip all of the clips holding in the circuitry. Remove the back case.
    • The circuitry will still be connected to the back case by ribbon cables.
  5. Nintendo Switch 修理キット
    ゲームを再開するための、早くて簡単な修理キット
    Switch 修理キットページへ
    Switch 修理キットページへ
  6. Open the case as shown.
    • Open the case as shown.
  7. Unclip the clip holding the ribbon cable in.
    • Unclip the clip holding the ribbon cable in.
    • Other ribbon cables might not have a clips.
  8. Pull the ribbon cable out.
    • Pull the ribbon cable out.
  9. Remove the 7 screws on the back side of the case, as shown in the picture.
    • Remove the 7 screws on the back side of the case, as shown in the picture.
    • Remove the metal plate.
  10. Remove the LCD plate, ribbon cables, and LCD display.
    • Remove the LCD plate, ribbon cables, and LCD display.
    • As you remove the backing you will see the LCD plate. It is a small ribbon cabled plate that is attached to the camera display.
    • Use extreme caution when removing the LCD plate, and be careful not to damage the display.
    • Watch out for loose buttons that may fall out. Keep all parts separate and organized.
  11. On the back cover you will have access to the button display.  Buttons can simply be grabbed and placed with your finger. Use this opportunity to clean any potentially dirty buttons or replace missing or damaged buttons.
    • On the back cover you will have access to the button display. Buttons can simply be grabbed and placed with your finger. Use this opportunity to clean any potentially dirty buttons or replace missing or damaged buttons.
    • Clean or replace the damaged buttons as needed.
    • Methods for cleaning include canned air spray or alcoholic cleaning fluid specialized for electronics.
終わりに
Trevor
メンバー登録日: 2011年01月20日
277 ポイント
6のガイドは作成済み
チーム
Cal Poly, Team 3-43, Regan Winter 2011 Cal Poly, Team 3-43, Regan Winter 2011人のメンバー
CPSU-REGAN-W11S3G43
4 メンバー
10のガイドは作成済み
コメント1件
It just doesn't work this way! Forgotten, but very important hints:
Before step 4: Do step 5 to 7 and remove the back case. Then clip off the one clip marked by a red circle in step 4. Disconnect the little red/black cable on the lens side, right next to the "2x optical zoom" writing on the case. Now the front case is still connected by a ribbon cable: In step 6 you can see the ribbon cable, which holds the back cover (and which you have just disconnected). Watch the small white connector marked in the picture with a red square. Right below the red square, you see another white connector (with no cable plugged in on the picture). This connector has no lock, like the one above, just pull the cable out. Now the back case is free!
Dennis.
http://minolta.eazypix.de
mincollect - 返信
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 3
今までの合計 2,215
