メインコンテンツにスキップ
Sony Cyber-shot DSC-HX90V Lens Replacement
必要な工具と部品
  1. Sony Cyber-shot DSC-HX90V Lens Replacement, Button board: 手順 1、 2の画像 1 Sony Cyber-shot DSC-HX90V Lens Replacement, Button board: 手順 1、 2の画像 2
    • Place the device so bottom of the camera is facing up .
    • Remove the five marked screws with a Phillips #000 screwdriver.
    • Insert the spudger where arrow marks to gently remove the lower panel.
  2. Sony Cyber-shot DSC-HX90V Lens Replacement: 手順 2、 1の画像 1
    • Remove the marked screw on the side of the camera with a Phillips #000 screwdriver.
  3. Sony Cyber-shot DSC-HX90V Lens Replacement: 手順 3、 1の画像 1
    • Remove the marked screw with a Phillips #000 screwdriver.
  4. Sony Cyber-shot DSC-HX90V Lens Replacement: 手順 4、 1の画像 1
    • Orient the device so the lens is facing down.
    • Remove the two black M1.4 X 3.5 Phillips head screws using Phillips #000 screwdriver.
  5. Sony Cyber-shot DSC-HX90V Lens Replacement: 手順 5、 1の画像 1
    • Remove the black M1.4 X 3.5 Phillips head screw.
  6. Sony Cyber-shot DSC-HX90V Lens Replacement, Side cover: 手順 6、 1の画像 1
    • Use the plastic opening tool with a prying motion to remove the side cover of the camera.
    • The cover should come off easily but you might hear light snapping or popping.
  7. Sony Cyber-shot DSC-HX90V Lens Replacement, LCD: 手順 7、 2の画像 1 Sony Cyber-shot DSC-HX90V Lens Replacement, LCD: 手順 7、 2の画像 2
    • Remove the small screw under the multi/USB cover.
    • Use the plastic opening tool to remove the button board.
  8. Sony Cyber-shot DSC-HX90V Lens Replacement: 手順 8、 2の画像 1 Sony Cyber-shot DSC-HX90V Lens Replacement: 手順 8、 2の画像 2
    • Disconnect the control board data cable with care. Permanent damage may occur to the control board if tools are used to disconnect the data cable. Use your fingers only.
    • Disconnect the control board data cable by wiggling carefully with your fingertips. Set the control board to the side once it is disconnected.
  9. Sony Cyber-shot DSC-HX90V Lens Replacement: 手順 9、 1の画像 1
    • LCD screen is very fragile. Handle with care. Do not use tools to remove the screen.
    • Lift the metal plate and LCD screen simultaneously until it is perpendicular to the camera.
  10. Sony Cyber-shot DSC-HX90V Lens Replacement, Motherboard: 手順 10、 2の画像 1 Sony Cyber-shot DSC-HX90V Lens Replacement, Motherboard: 手順 10、 2の画像 2
    • Remove the ribbon cable connecting LCD display to camera sensor and battery housing.
  11. Sony Cyber-shot DSC-HX90V Lens Replacement: 手順 11、 1の画像 1
    • Make sure all ribbon cables are unplugged and remove the motherboard.
    • Ribbon wires can be easily damaged.
  12. Sony Cyber-shot DSC-HX90V Lens Replacement, Lens: 手順 12、 3の画像 1 Sony Cyber-shot DSC-HX90V Lens Replacement, Lens: 手順 12、 3の画像 2 Sony Cyber-shot DSC-HX90V Lens Replacement, Lens: 手順 12、 3の画像 3
    • Press on the lens with your finger.
    • Gently pull the lens container out of the camera.
    • Make sure all ribbon wires are unplugged.
終わりに
8 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Marin Rusinov
メンバー登録日: 02/02/17
853 ポイント
5のガイドは作成済み
5 件のコメント
Aside from a few missed screws, very nicely done. And I suspect that if one didn’t realize the need to remove those screws, sh/e probably shouldn’t be attempting the job in the first place. :) (I noted the comments after completing lens removal.)
Leon - 返信
Can you comment where/specifically the missing screws that were not listed can be found? Any other guides out there that are more comprehensive?
Eric C -
Under multi cover
Dufour - 返信
First at step 7
Dufour -
At step 8 remove two 2mm screws both lower sides of LCD
Dufour - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 28
過去 30 日: 115
今までの合計 12,473
