はじめに
Is the View Finder not working even after the LCD/Finder button has been pressed? Then the View Finder may need replacing.
必要な工具と部品
Remove the 3 (4 cm) Philips head screws holding the plastic camera housing together. They are located on the back of the camera.
Remove the 2 (4 cm) Phillips head screws on the right side of the camera.
Turn the camera upside down and remove the remaining 3 (4 cm) Phillips head screws holding the plastic housing together.
ある他の人がこのガイドを完成しました。
