この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
If the LCD screen is not powering on even after the LCD/Finder button has been pressed twice. Then the screen or possibly the circuit board may need to be replaced.
必要な工具と部品
Use a Phillips head screwdriver to remove one 2 cm screw located on the inside portion of the LCD hinge.
Once the plastic housing is separated, disconnect the ribbon wire located on the back of the LCD display. This can be achieved by pulling up lightly on the brown bar that locks the ribbon wire to the circuit board..
Disconnect the remaining two ribbon wires the same way. They are located on the right rear side of the LCD frame.
To reassemble your device, follow these instructions in reverse order. It is important to follow the steps in this order as it may not turn on properly if the user does not follow every step.
2 の人々がこのガイドを完成させました。
3 件のコメント
Comment réparer la carte circuit imprimé de l'écran? Il y'a un transistor qui reçoit 3.7v et qui laisse rien sortir
