メインコンテンツにスキップ
Sony Cyber-shot DSC-HX300 HDMI/USB port Replacement
必要な工具と部品
  1. Sony Cyber-shot DSC-HX300 HDMI/USB port Replacement, Battery: 手順 1、 1の画像 1
    • Make sure the camera is powered off
    • Turn the camera upside down. This is a view of the bottom of the camera.
  2. Sony Cyber-shot DSC-HX300 HDMI/USB port Replacement: 手順 2、 1の画像 1
    • Push battery cover away from the camera.
  3. Sony Cyber-shot DSC-HX300 HDMI/USB port Replacement: 手順 3、 1の画像 1
    • Push the blue tab that secures the battery. The battery will then spring out.
  4. Sony Cyber-shot DSC-HX300 HDMI/USB port Replacement: 手順 4、 2の画像 1 Sony Cyber-shot DSC-HX300 HDMI/USB port Replacement: 手順 4、 2の画像 2
    • Remove the battery.
  5. Sony Cyber-shot DSC-HX300 HDMI/USB port Replacement, Motherboard: 手順 5、 3の画像 1 Sony Cyber-shot DSC-HX300 HDMI/USB port Replacement, Motherboard: 手順 5、 3の画像 2 Sony Cyber-shot DSC-HX300 HDMI/USB port Replacement, Motherboard: 手順 5、 3の画像 3
    • Make sure to remove the battery before disassembly to prevent electrocution.
    • Remove the 3 (4 cm) Phillips head screws located on the back of the camera.
    • Remove the 2 (4 cm) Phillips head screws on the right side of the camera.
    • Turn the camera upside down to remove the remaining the 3 (4 cm) Phillips head screws holding the plastic camera housing together.
  6. Sony Cyber-shot DSC-HX300 HDMI/USB port Replacement: 手順 6、 2の画像 1 Sony Cyber-shot DSC-HX300 HDMI/USB port Replacement: 手順 6、 2の画像 2
    • Using a plastic opening tool, separate the plastic camera housing.
  7. Sony Cyber-shot DSC-HX300 HDMI/USB port Replacement: 手順 7、 1の画像 1
    • Disconnect the ribbon wire attaching the screen to the camera.
  8. Sony Cyber-shot DSC-HX300 HDMI/USB port Replacement: 手順 8、 3の画像 1 Sony Cyber-shot DSC-HX300 HDMI/USB port Replacement: 手順 8、 3の画像 2 Sony Cyber-shot DSC-HX300 HDMI/USB port Replacement: 手順 8、 3の画像 3
    • Carefully remove the 7 ribbon wires connected to the mother board.
    • Remove the 2 (5 cm) Phillips head screws on the speaker mounting bracket.
    • Remove the 3 (4 cm) Phillips head screws that secure the motherboard to the camera.
    • Lift up on the speaker mounting bracket to remove it.
  9. Sony Cyber-shot DSC-HX300 HDMI/USB port Replacement: 手順 9、 2の画像 1 Sony Cyber-shot DSC-HX300 HDMI/USB port Replacement: 手順 9、 2の画像 2
    • Carefully disconnect the ribbon wire connecting the HDMI port to the Motherboard.
    • Once the Motherboard is removed the replacement can be installed.
  10. Sony Cyber-shot DSC-HX300 HDMI/USB port Replacement, HDMI/USB port: 手順 10、 1の画像 1
    • Remove the 3 (4 cm) Phillips head screws securing a mounting bracket over the HDMI/USB Port.
  11. Sony Cyber-shot DSC-HX300 HDMI/USB port Replacement: 手順 11、 1の画像 1
    • Lift up on the mounting bracket to remove the HDMI/USB Port from the camera.
  12. Sony Cyber-shot DSC-HX300 HDMI/USB port Replacement: 手順 12、 1の画像 1
    • Once the HDMI/USB Port is removed the replacement can be installed.
終わりに
2 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Elizabeth Surface
メンバー登録日: 08/26/15
1,465 ポイント
9のガイドは作成済み
チーム
USF Tampa, Team 4-6, Meier Fall 2015 USF Tampa, Team 4-6, Meier Fall 2015人のメンバー
USFT-MEIER-F15S4G6
4 メンバー
18のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 13
今までの合計 1,554
