はじめに
Your camera's case may be damaged or you may wish to access parts below it. This guide with explain how to safely remove the case so that it, or a new one, can be placed again.
  1. Unscrew the screws on the right side of the camera.
    • Unscrew the screws on the right side of the camera.
  2. Free shipping on all orders over $100 or containing a Pro Tech Toolkit!
    当社のショップを閲覧する
  3. Using a plastic opening tool, lift and remove the silver piece on the right side of the camera. Using a plastic opening tool, lift and remove the silver piece on the right side of the camera.
    • Using a plastic opening tool, lift and remove the silver piece on the right side of the camera.
  4. Use a plastic opening tool to push the tabs on each side of the front case forward. Remove the front case. Remove the front case.
    • Use a plastic opening tool to push the tabs on each side of the front case forward.
    • Remove the front case.
まとめ
Dana Sanchez
メンバー登録日: 2014年10月21日
15 ポイント
3のガイドは作成済み
チーム
USF Tampa, Team 1-5, Leahy Fall 2014 USF Tampa, Team 1-5, Leahy Fall 2014人のメンバー
USFT-LEAHY-F14S1G5
4 メンバー
5のガイドは作成済み
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 185
