メインコンテンツにスキップ
Sony Cyber-Shot DSC-TX30 Movie Button Replacement
必要な工具と部品
  1. Sony Cyber-Shot DSC-TX30 Movie Button Replacement, Battery: 手順 1、 2の画像 1 Sony Cyber-Shot DSC-TX30 Movie Button Replacement, Battery: 手順 1、 2の画像 2
    • Using your finger, slide the release catch to unlock the battery/memory card cover.
  2. Sony Cyber-Shot DSC-TX30 Movie Button Replacement: 手順 2、 2の画像 1 Sony Cyber-Shot DSC-TX30 Movie Button Replacement: 手順 2、 2の画像 2
    • Open the battery/memory card door.
  3. Sony Cyber-Shot DSC-TX30 Movie Button Replacement: 手順 3、 2の画像 1 Sony Cyber-Shot DSC-TX30 Movie Button Replacement: 手順 3、 2の画像 2
    • Push the battery eject lever to free the battery.
  4. Sony Cyber-Shot DSC-TX30 Movie Button Replacement: 手順 4、 1の画像 1
    • Remove the battery from the device.
  5. Sony Cyber-Shot DSC-TX30 Movie Button Replacement, Outer Shell: 手順 5、 1の画像 1
    • Using a Phillips #00 screwdriver, remove one black 2 2/5mm screw that is located next to the wrist band loop.
  6. Sony Cyber-Shot DSC-TX30 Movie Button Replacement: 手順 6、 1の画像 1
    • Using the plastic opening tool, separate the edge-casing from the rest of the camera.
  7. Sony Cyber-Shot DSC-TX30 Movie Button Replacement: 手順 7、 2の画像 1 Sony Cyber-Shot DSC-TX30 Movie Button Replacement: 手順 7、 2の画像 2
    • Pull the edge-casing off of the camera.
  8. Sony Cyber-Shot DSC-TX30 Movie Button Replacement: 手順 8、 1の画像 1
    • Using a Phillips #00 screwdriver, remove one silver 3mm screw located on the front side of the camera.
    • Using a Phillips #00 screwdriver, remove one silver 5 2/5mm screw located on the front side of the camera
    • Using a Phillips #00 screwdriver, remove one black 2 1/2mm screw located on the front side of the camera.
  9. Sony Cyber-Shot DSC-TX30 Movie Button Replacement: 手順 9、 1の画像 1
    • Using a Phillips #00 screwdriver, remove one 2 1/2mm screw located near the wrist strap.
  10. Sony Cyber-Shot DSC-TX30 Movie Button Replacement: 手順 10、 1の画像 1
    • Using a Phillips #00 screwdriver remove one black 2 2/5mm screw near the tripod slot on the bottom of the casing.
  11. Sony Cyber-Shot DSC-TX30 Movie Button Replacement: 手順 11、 1の画像 1
    • Using a Phillips #00 screwdriver remove the two 2 2/5mm black screws from the side of the camera opposite of the wrist strap
  12. Sony Cyber-Shot DSC-TX30 Movie Button Replacement: 手順 12、 2の画像 1 Sony Cyber-Shot DSC-TX30 Movie Button Replacement: 手順 12、 2の画像 2
    • Using the plastic opening tool, open the device's outer shell.
  13. Sony Cyber-Shot DSC-TX30 Movie Button Replacement: 手順 13、 2の画像 1 Sony Cyber-Shot DSC-TX30 Movie Button Replacement: 手順 13、 2の画像 2
    • Remove the front casing of the device.
  14. Sony Cyber-Shot DSC-TX30 Movie Button Replacement, Back Casing: 手順 14、 3の画像 1 Sony Cyber-Shot DSC-TX30 Movie Button Replacement, Back Casing: 手順 14、 3の画像 2 Sony Cyber-Shot DSC-TX30 Movie Button Replacement, Back Casing: 手順 14、 3の画像 3
    • Using the plastic opening tool, remove the back casing of the device.
  15. Sony Cyber-Shot DSC-TX30 Movie Button Replacement, Movie Button: 手順 15、 2の画像 1 Sony Cyber-Shot DSC-TX30 Movie Button Replacement, Movie Button: 手順 15、 2の画像 2
    • Using the tweezers, remove the movie button from the back casing of the device.
終わりに
作成者
3人の作成者と共同で作成されました。
Kellen Fulkerson
メンバー登録日: 04/11/17
689 ポイント
6のガイドは作成済み
チーム
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 267
