メインコンテンツにスキップ
Sony Cyber-Shot DSC-S90 Motherboard Replacement
必要な工具と部品
  1. Sony Cyber-Shot DSC-S90 Motherboard Replacement, Batteries: 手順 1、 2の画像 1 Sony Cyber-Shot DSC-S90 Motherboard Replacement, Batteries: 手順 1、 2の画像 2
    • Hold down the "open"button (gray oval with arrow pointing upwards) on the battery port door.
    • While holding the button downwards, slide the door upwards to unlock and open the door.
  2. Sony Cyber-Shot DSC-S90 Motherboard Replacement: 手順 2、 1の画像 1
    • Pull open the door and allow the batteries to fall out.
  3. Sony Cyber-Shot DSC-S90 Motherboard Replacement, Back Case: 手順 3、 2の画像 1 Sony Cyber-Shot DSC-S90 Motherboard Replacement, Back Case: 手順 3、 2の画像 2
    • Remove the 2mm Phillips #00 screw under the battery port door.
    • Remove the 2mm Phillips #00 screw towards the right of the bottom-side of the camera.
  4. Sony Cyber-Shot DSC-S90 Motherboard Replacement: 手順 4、 2の画像 1 Sony Cyber-Shot DSC-S90 Motherboard Replacement: 手順 4、 2の画像 2
    • Remove the two 2mm Phillips #00 screws (one on each side of the camera).
  5. Sony Cyber-Shot DSC-S90 Motherboard Replacement: 手順 5、 2の画像 1 Sony Cyber-Shot DSC-S90 Motherboard Replacement: 手順 5、 2の画像 2
    • Use an opening tool to unlock the front case from the main body of the camera. Use the tool on the right side and bottom of the camera with the LCD screen facing you.
  6. Sony Cyber-Shot DSC-S90 Motherboard Replacement: 手順 6、 1の画像 1
    • Pull apart the back case from the main body of the camera.
  7. Sony Cyber-Shot DSC-S90 Motherboard Replacement, Front Case: 手順 7、 1の画像 1
    • Use an opening tool to unlock the front case from the main body of the camera. Use the tool on the top of the camera.
  8. Sony Cyber-Shot DSC-S90 Motherboard Replacement: 手順 8、 1の画像 1
    • Pull apart the front case from the main body of the camera.
  9. Sony Cyber-Shot DSC-S90 Motherboard Replacement, Top/Side Case: 手順 9、 3の画像 1 Sony Cyber-Shot DSC-S90 Motherboard Replacement, Top/Side Case: 手順 9、 3の画像 2 Sony Cyber-Shot DSC-S90 Motherboard Replacement, Top/Side Case: 手順 9、 3の画像 3
    • Release all clips and latches keeping the casing in place using a spudger, opening tool, or screwdriver.
  10. Sony Cyber-Shot DSC-S90 Motherboard Replacement: 手順 10、 1の画像 1
    • Now the casing can be removed after all latches have been undone.
  11. Sony Cyber-Shot DSC-S90 Motherboard Replacement, Battery Terminal: 手順 11、 3の画像 1 Sony Cyber-Shot DSC-S90 Motherboard Replacement, Battery Terminal: 手順 11、 3の画像 2 Sony Cyber-Shot DSC-S90 Motherboard Replacement, Battery Terminal: 手順 11、 3の画像 3
    • Disconnect the ribbon cables on top of the battery terminal using a spudger or screwdriver.
  12. Sony Cyber-Shot DSC-S90 Motherboard Replacement: 手順 12、 1の画像 1
    • Disconnect the remaining ribbon cable on the side of the camera using a spudger or screwdriver.
  13. Sony Cyber-Shot DSC-S90 Motherboard Replacement: 手順 13、 1の画像 1
    • Use a spudger or screwdriver to unhinge the clips. This releases the battery terminal.
  14. Sony Cyber-Shot DSC-S90 Motherboard Replacement: 手順 14、 1の画像 1
    • Once the battery terminal is unclipped, pull this ribbon cable out with a spudger or screwdriver to finish freeing the battery terminal.
  15. Sony Cyber-Shot DSC-S90 Motherboard Replacement: 手順 15、 1の画像 1
    • Now the battery terminal can be separated from the main body of the camera.
  16. Sony Cyber-Shot DSC-S90 Motherboard Replacement, Motherboard: 手順 16、 3の画像 1 Sony Cyber-Shot DSC-S90 Motherboard Replacement, Motherboard: 手順 16、 3の画像 2 Sony Cyber-Shot DSC-S90 Motherboard Replacement, Motherboard: 手順 16、 3の画像 3
    • Disconnect the three pictured ribbon cables using a spudger or screwdriver.
  17. Sony Cyber-Shot DSC-S90 Motherboard Replacement: 手順 17、 1の画像 1
    • Push the clip to the left and lift the motherboard upwards and away from the camera.
  18. Sony Cyber-Shot DSC-S90 Motherboard Replacement: 手順 18、 2の画像 1 Sony Cyber-Shot DSC-S90 Motherboard Replacement: 手順 18、 2の画像 2
    • Disconnect the two ribbon cables using a spudger or screwdriver.
  19. Sony Cyber-Shot DSC-S90 Motherboard Replacement: 手順 19、 1の画像 1
    • Unlatch the clip and lift the motherboard upwards and away from the camera.
終わりに
作成者
4人の作成者と共同で作成されました。
Jonathan Arns
メンバー登録日: 10/28/19
745 ポイント
8のガイドは作成済み
チーム
UMass Dartmouth, Team S4-G5, Saloman Fall 2019 UMass Dartmouth, Team S4-G5, Saloman Fall 2019人のメンバー
UMASSD-SALOMAN-F19S4G5
3 メンバー
20のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 7
過去 30 日: 8
今までの合計 245
