はじめに
Installing a new speaker fairly simple as it only involves opening the device casing and then removing the broken speaker.
パーツ
パーツは必要ありません。
  1. Unscrew the 1.9mm screw located at the top of the device with a Phillips #00 screwdriver.
    • Unscrew the 1.9mm screw located at the top of the device with a Phillips #00 screwdriver.
    • It may be helpful to set up a piece of paper to keep track of where removed screws came from.
  2. Unscrew the 2.5mm screw located on the left side of the device with a Phillips #00 screwdriver.
    • Unscrew the 2.5mm screw located on the left side of the device with a Phillips #00 screwdriver.
  3. Free shipping on all orders over $100.00 or containing a Pro Tech Toolkit!
    当社のショップを閲覧する
    Ever fixed something? That’s Genius.
    Share your repair story with #ImAGenius
    We Are All Geniuses
  4. Unscrew the five 2.5mm screws on the back panel with a Phillips #00 screwdriver. Remove the back panel by lifting it away with your hands.
    • Unscrew the five 2.5mm screws on the back panel with a Phillips #00 screwdriver.
    • Remove the back panel by lifting it away with your hands.
  5. Use tweezers to unplug the speaker wire from the motherboard by pulling the plug (not the wires) down towards the speaker. Be careful not to tear the speaker wires! They are very thin.
    • Use tweezers to unplug the speaker wire from the motherboard by pulling the plug (not the wires) down towards the speaker.
    • Be careful not to tear the speaker wires! They are very thin.
    • Remove the tape holding speaker wire by peeling it away.
  6. Holding down the speaker rail unscrew the two 2.5mm screws with a Phillips #00 screwdriver.
    • Holding down the speaker rail unscrew the two 2.5mm screws with a Phillips #00 screwdriver.
    • Remove the speaker rail vertically from the device.
  7. Hold back the plastic tabs to pop the speaker out of the rail.
    • Hold back the plastic tabs to pop the speaker out of the rail.
まとめ
Daniel Soski
メンバー登録日: 2013年04月18日
20 ポイント
6のガイドは作成済み
チーム
Cal Poly, Team 14-11, Maness Spring 2013 Cal Poly, Team 14-11, Maness Spring 2013人のメンバー
CPSU-MANESS-S13S14G11
5 メンバー
8のガイドは作成済み
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 186
