メインコンテンツにスキップ
修理を始めるには
修理する権利
ストア
パーツ
パーツは指定されていません。
  1. Remove the battery cover on the back of the boombox by applying downward pressure to the two clamps. Be sure to unplug the boombox from the wall before attempting to open it for repair. Be sure to unplug the boombox from the wall before attempting to open it for repair.
    • Remove the battery cover on the back of the boombox by applying downward pressure to the two clamps.
    • Be sure to unplug the boombox from the wall before attempting to open it for repair.
  2. Push against the positive end of each battery. Once it is loose, lift the battery out. Repeat for all six batteries. The top row of batteries have the positive side pointing right. The bottom row of batteries have the positive side pointing left.
    • Push against the positive end of each battery. Once it is loose, lift the battery out. Repeat for all six batteries.
    • The top row of batteries have the positive side pointing right. The bottom row of batteries have the positive side pointing left.
  3. Hold the boombox handle at an angle to access the screws behind the CD player. Use a  Phillips #1 screwdriver to unscrew the top two 14 mm screws. You may need a flashlight to see the screws. Use a  Phillips #1 screwdriver to unscrew the top two 14 mm screws. You may need a flashlight to see the screws.
    • Hold the boombox handle at an angle to access the screws behind the CD player.
    • Use a Phillips #1 screwdriver to unscrew the top two 14 mm screws. You may need a flashlight to see the screws.
  4. Remove four 14 mm screws using a Phillips #1 screwdriver. Two of these screws are at the bottom of the boombox and the other two are on either side of the boombox as highlighted in the related images. All four screws have black arrows (not visible in the photo) indicating their location on the boombox.
    • Remove four 14 mm screws using a Phillips #1 screwdriver. Two of these screws are at the bottom of the boombox and the other two are on either side of the boombox as highlighted in the related images.
    • All four screws have black arrows (not visible in the photo) indicating their location on the boombox.
  5. Gently separate the front panel from the back panel. Remove the two connections holding the front panel to boombox. One connection is located on the upper left hand side of the main circuit board.
    • Gently separate the front panel from the back panel.
    • Remove the two connections holding the front panel to boombox.
    • One connection is located on the upper left hand side of the main circuit board.
    • The other is a large white strip slightly to the right of the cassette player.
    • Do not touch the cylindrical parts on the circuit board. These are capacitors and may deliver a shock!
    • Remove the front panel.
  6. Unscrew the 3x12 screws circled in the photo using a #1 Phillips screwdriver.
    • Unscrew the 3x12 screws circled in the photo using a #1 Phillips screwdriver.
  7. Carefully disconnect the wire connection by pulling at its base.
    • Carefully disconnect the wire connection by pulling at its base.
  8. Unscrew the 5mm screw shown in the photo. Note the small latch on the side of assembly as you remove the motor. Note the small latch on the side of assembly as you remove the motor.
    • Unscrew the 5mm screw shown in the photo.
    • Note the small latch on the side of assembly as you remove the motor.
  9. Remove the motor belt from its axle. Remove the motor belt from its axle.
    • Remove the motor belt from its axle.
終わりに
3 の人々がこのガイドを完成させました。
Wil Gilbreath
メンバー登録日: 2014年10月14日
181 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 10-38, Amido Fall 2014 Cal Poly, Team 10-38, Amido Fall 2014人のメンバー
CPSU-AMIDO-F14S10G38
5 メンバー
7のガイドは作成済み
2 件のコメント
need belt for cassette replace
joe jefferson - 返信
need the belt for the cassette player
joe jefferson - 返信
コメントを追加
統計データを表示:
過去 24時間: 3
過去 7 日: 21
過去 30 日: 74
今までの合計 10,760
