メインコンテンツにスキップ
Sony CFD-8 LCD Board Replacement
必要な工具と部品
  1. Sony CFD-8 LCD Board Replacement, Battery: 手順 1、 3の画像 1 Sony CFD-8 LCD Board Replacement, Battery: 手順 1、 3の画像 2 Sony CFD-8 LCD Board Replacement, Battery: 手順 1、 3の画像 3
    • Remove the battery cover on the back of the boombox by applying downward pressure to the two clamps.
    • Be sure to unplug the boombox from the wall before attempting to open it for repair.
  2. Sony CFD-8 LCD Board Replacement: 手順 2、 2の画像 1 Sony CFD-8 LCD Board Replacement: 手順 2、 2の画像 2
    • Push against the positive end of each battery. Once it is loose, lift the battery out. Repeat for all six batteries.
    • The top row of batteries have the positive side pointing right. The bottom row of batteries have the positive side pointing left.
  3. Sony CFD-8 LCD Board Replacement, Front Panel: 手順 3、 3の画像 1 Sony CFD-8 LCD Board Replacement, Front Panel: 手順 3、 3の画像 2 Sony CFD-8 LCD Board Replacement, Front Panel: 手順 3、 3の画像 3
    • Hold the boombox handle at an angle to access the screws behind the CD player.
    • Use a Phillips #1 screwdriver to unscrew the top two 14 mm screws. You may need a flashlight to see the screws.
  4. Sony CFD-8 LCD Board Replacement: 手順 4、 2の画像 1 Sony CFD-8 LCD Board Replacement: 手順 4、 2の画像 2
    • Remove four 14 mm screws using a Phillips #1 screwdriver. Two of these screws are at the bottom of the boombox and the other two are on either side of the boombox as highlighted in the related images.
    • All four screws have black arrows (not visible in the photo) indicating their location on the boombox.
  5. Sony CFD-8 LCD Board Replacement: 手順 5、 3の画像 1 Sony CFD-8 LCD Board Replacement: 手順 5、 3の画像 2 Sony CFD-8 LCD Board Replacement: 手順 5、 3の画像 3
    • Gently separate the front panel from the back panel.
    • Remove the two connections holding the front panel to boombox.
    • One connection is located on the upper left hand side of the main circuit board.
    • The other is a large white strip slightly to the right of the cassette player.
    • Do not touch the cylindrical parts on the circuit board. These are capacitors and may deliver a shock!
    • Remove the front panel.
  6. Sony CFD-8 LCD Board Replacement, LCD Board: 手順 6、 1の画像 1
    • Remove three 5mm screws from the back of the circuit board with a Phillips #1 screwdriver.
  7. Sony CFD-8 LCD Board Replacement: 手順 7、 1の画像 1
    • Remove the circuit board.
終わりに
作成者
1人の作成者と共同作成されました。
Andrew Kleve
メンバー登録日: 10/12/14
271 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team 10-38, Amido Fall 2014 Cal Poly, Team 10-38, Amido Fall 2014人のメンバー
CPSU-AMIDO-F14S10G38
5 メンバー
7のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 4
今までの合計 580
