この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
If your device is not turning on and you're using batteries as a power source, you can use this guide to remove or replace the batteries. Be sure to remove the batteries and unplug the device before taking it apart to avoid electric shock.
Remove the battery cover on the back of the boombox by applying downward pressure to the two clamps.
もう少しです!
終わりに
