はじめに
This guide will show how to remove the back panel to be able to work inside of the device.
Before any repair work can be done one must remove the device for the vehicle. To do so follow this link to see a general vehicle removal of a stereo system.
パーツ
パーツは必要ありません。
  1. Locate the clip on the wiring harness.
    • Locate the clip on the wiring harness.
  2. Press down on the clip like you would an Ethernet cable. Rock harness side to side, pulling gently towards you until harness detaches.
    • Press down on the clip like you would an Ethernet cable.
    • Rock harness side to side, pulling gently towards you until harness detaches.
  3. Free shipping on all orders over $100 or containing a Pro Tech Toolkit!
    当社のショップを閲覧する
  4. Locate back panel.
    • Locate back panel.
  5. Remove four 11.5mm Phillips #00 (silver) screws from back panel. Remove four 11.5mm Phillips #00 (silver) screws from back panel. Remove four 11.5mm Phillips #00 (silver) screws from back panel.
    • Remove four 11.5mm Phillips #00 (silver) screws from back panel.
  6. Remove four 9.5mm Phillips #00 (black) screws from back panel.
    • Remove four 9.5mm Phillips #00 (black) screws from back panel.
    • Remove two 7.5mm Phillips #00 (black) screws from back panel.
  7. Remove back panel.
    • Remove back panel.
    • On the back panel there will be thermal (white) paste. Do not touch.
まとめ
ある他の人がこのガイドを完成しました。
Odelkys Marquez
メンバー登録日: 2014年09月22日
953 ポイント
7のガイドは作成済み
チーム
USF Tampa, Team 10-2, Brown Fall 2014 USF Tampa, Team 10-2, Brown Fall 2014人のメンバー
USFT-BROWN-F14S10G2
3 メンバー
7のガイドは作成済み
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 563
