メインコンテンツにスキップ
Sony CCD-TR81 Outer Case Replacement
必要な工具と部品
  1. Sony CCD-TR81 Outer Case Replacement, Disassembling Sony CCD-TR81 Battery: 手順 1、 1の画像 1
    • Lift viewfinder to access battery pack.
  2. Sony CCD-TR81 Outer Case Replacement: 手順 2、 2の画像 1 Sony CCD-TR81 Outer Case Replacement: 手順 2、 2の画像 2
    • Press the battery release button.
    • While pushing the battery button, slide the battery to the left.
  3. Sony CCD-TR81 Outer Case Replacement: 手順 3、 1の画像 1
    • Pull the battery pack out of the video camera.
  4. Sony CCD-TR81 Outer Case Replacement, Outer Case: 手順 4、 3の画像 1 Sony CCD-TR81 Outer Case Replacement, Outer Case: 手順 4、 3の画像 2 Sony CCD-TR81 Outer Case Replacement, Outer Case: 手順 4、 3の画像 3
    • Open the cassette cover.
    • Unscrew 14 screws located on the outer casing. Three are located on the top face 2x6.8mm and 1X4.54mm, three on the left face 1x4.54mm,1x5.3mm and seven on the bottom face 5x4.54mm and 2x6.77mm.
  5. Sony CCD-TR81 Outer Case Replacement: 手順 5、 2の画像 1 Sony CCD-TR81 Outer Case Replacement: 手順 5、 2の画像 2
    • Remove five screws from the right side, from bottom to top, 3x4.54mm 2x5.70mm.
    • Remove the single 4.5 mm screw from the backside.
  6. Sony CCD-TR81 Outer Case Replacement: 手順 6、 1の画像 1
    • Pull off the plastic tape cover by lifting it up and out of the camera base.
  7. Sony CCD-TR81 Outer Case Replacement: 手順 7、 1の画像 1
    • Disconnect the mic assembly by pulling it away from the camera base.
    • Do not pull too hard as the wires are still connected.
  8. Sony CCD-TR81 Outer Case Replacement: 手順 8、 1の画像 1
    • Pull the bottom part of the case away from the camera.
  9. Sony CCD-TR81 Outer Case Replacement: 手順 9、 1の画像 1
    • Remove the three 4.5 mm screws from the right face of the video camera.
  10. Sony CCD-TR81 Outer Case Replacement: 手順 10、 1の画像 1
    • Remove the single 3.6 mm screw at the front of the video camera on the circuit board.
  11. Sony CCD-TR81 Outer Case Replacement: 手順 11、 1の画像 1
    • Pull the audio/video inputs underneath the microphone assembly. The inputs should still be connected to the circuit board.
  12. Sony CCD-TR81 Outer Case Replacement: 手順 12、 1の画像 1
    • Remove two remaining 3.6 mm case screws from the front of the camera.
  13. Sony CCD-TR81 Outer Case Replacement: 手順 13、 2の画像 1 Sony CCD-TR81 Outer Case Replacement: 手順 13、 2の画像 2
    この手順で使用する道具:
    購入する
    • Using metal tweezers, pull out the plastic connector box on the front side.
    • Again use metal tweezers to pull out the connection box on the bottom of the camera. The right side of the case can now be removed by pulling it to the right.
終わりに
ある他の人がこのガイドを完成しました。
作成者
7人の作成者と共同で作成されました。
Kevin
メンバー登録日: 01/24/11
232 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team 11-25, Maness Winter 2011 Cal Poly, Team 11-25, Maness Winter 2011人のメンバー
CPSU-MANESS-W11S11G25
4 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 16
今までの合計 3,412
