はじめに
The USB is a very important part of the Sony Bloggie as it is the only way to get your movies from the camera to a computer. This guide will show you how to install a new USB drive in the Sony Bloggie 3D.
必要な工具と部品
この手順で使用する道具:Tweezers$4.99
Using your hand, or a pair of tweezers, remove the ZIF connector by gently pulling it out of the dock on the circuit board.
Once the back cover is removed, by using the opening tool, remove the following screws using a Phillips #00 screwdriver.
Two 4.0mm Phillips #00 screws
One 8.0mm Phillips #00 screw
One 9.5mm Phillips #00 screw
