はじめに
Whether it's by dust or wear, the Main Button's Circuit Board can malfunction over time. This guide focuses on how to install a new Main Button's Circuit Board to get your device running like new.
  1. Remove the two 2.5mm Phillips #00 screws using the Philips #00 screwdriver.
    • Remove the two 2.5mm Phillips #00 screws using the Philips #00 screwdriver.
  2. Free shipping on all orders over $100.00 or containing a Pro Tech Toolkit!
    当社のショップを閲覧する
  3. Use a plastic opening tool to pry the cover open. After the the cover is partly open as shown, remove the cover with your hands.
    • Use a plastic opening tool to pry the cover open.
    • After the the cover is partly open as shown, remove the cover with your hands.
  4. Detach the board from the ZIF connector using pair of tweezers or by hand. Flip the circuit board over and remove the connector that is on the backside, now you can safely remove the circuit board.
    • Detach the board from the ZIF connector using pair of tweezers or by hand.
    • Flip the circuit board over and remove the connector that is on the backside, now you can safely remove the circuit board.
まとめ
Robert Tam
メンバー登録日: 2013年01月30日
6 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team 7-12, Maness Winter 2013 Cal Poly, Team 7-12, Maness Winter 2013人のメンバー
CPSU-MANESS-W13S7G12
5 メンバー
6のガイドは作成済み
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 276
